Last edit by: IB Advertising
Browse all: Toyota 4Runner Engine Guides
- Toyota 4Runner 1996-2002: How to Replace Air Filter
Step by step instructions for do-it-yourself repairs.
3rd gen 4runner intake / air filter combo
okay after hours of research I've came to conclusion the k&n fipks suck and are out the question
I've came across airaid intake MITs or true flow intake tubes with use of stock airbox with deckplate mod is usually best? or amsoil air filters too
but what is the best combo in your opinions and why? looking for best combo but can't decide what is best. I'd figure I'd take advice from those who already done it
I'm doing deckplate mod same time as my intake and air filter upgrade
thanks for help in advance
I'd do the ISR and deckplate... and I just got advice that the True Flow filters use oil that isn't bad for the stock MAF sensor... and they collect more dirt... so I went to the local exhaust shop and had them cut a length of pipe that was the closest diameter to the Intake Silencer and had them weld on a connection tube and they opened it up to the right diameter so I essentially created the "tube" section of a aftermarket cold-air intake kit...then did the deckplate to replicate (sp?) the cold air filter part....using a high flow filter... does that help?
so wait does that mean that the places still sell their product.. i shouldnt buy it?
i mean i wanted just the intake tube the one that still connects to all my stock air box and vacuum lines and everything. just helps get rid of the intake silencer and then i wanted to do deck plate mod and it comes with a true flow filter.
so is that not the way to go anymore?
haha shoot i was just about to buy it this weekend.
should i try the AFE? wher edo you buy them? are they expensive?
oh i see..
now i get it when you mean. shoot, so what should i do with everything? ahah true flow was where i was aiming.
hmm so whats a good intake tube that i guess uses stock airbox? and i can just do the deckplate mod? with a AFE or whatever else high flow filter?
should i deckplate first then the MIT or just wait and do it all the same time?
i was planning on ordeing the airaid today thats why
haah thanks
but how is the airaid fiter? is that one any good? im planning to order from burtsmanindustries and wondeiring is i should pay the extra 40 for the filter?
haah thanks
Hey guys Yotas up? I have a question, I just recently bought a 1996 limited 4x4 runner to add to my collection of runners and wow does that 3.4 put the 3.0 in the dust. The 96 is all stock except for flowmaster exhaust and a stock fittment K&N air filter. The 91 got a leveling and about 2"/3" lift with 31 10.50 BFG AT/KO's but is otherwise stock. I need a few things for the 96 so I did a search on ebay for "1996 4runner" and came across a kit for the intake and would appreciate your take on this. It is a bypass for the throttle body to reroute the hot coolant around the throttle body and caps the old inlet/outlets. Claims only minor performance improvement from intaking cooler air but is only like 15 bucks, and they do not recommend using it in real cold climates at least not during cold months. I live in Arizona and was thinking if this would help even if only just slighly I could do this without a silly kit. An explanation of pros or cons would be appreciated to help me better understand this cold air intake stuff. Happy Yota trails! Jimmy
On top of the poor quality my "kit" did not include the hardware to hold the tube steady so it would flop around and eventually come loose from the throttle intake. Also I did not get enough hoses and the ones supplied were weak and would collapse under the heat. After my experience I put my factory intake back on and never messed with it. Don't waste your money, just search deckplate mod and ISR mod and you'll be fine. I have not done it yet, but to save yourself future headache learn from MY ignorance.
Whoops I misread your post I thought you were talking about intake kit, but anyways... another "gotcha" is those resistors you can buy to make your engine think it's running cooler to dump more fuel while adding hp is crap. You have to realize the ECU reads many parameters such as IAT, MAF, ECT, TPS, engine load, and various others so you aren't truly fooling the ECU. I've seen them and they are like $10 but you can go to Radio Shack and buy the same resistor for under a buck, either way it's useless. Typically in performance you will get what you pay for. As far as the ISR and deckplate mode it was actually dyno tested by I forget who on here. But it was tested and actually works.
Well, look at it this way. Since Trueflow is going out of business there are going to be no more oiling kits, the oiling kits that will be left will be overpriced (I've seen some starting to go for $25) and would cost about the same amount as a paper filter from the dealer making a Trueflow filter useless IMO.
If you can still buy the trueflow filter I would, never buy another filter again, just clean and reoil, far from "useless."
Airaid MIT + TruFlow here.
It was replaced by Twin Air filters; doesn't look like amsoil has a foam filter for passenger vehicles anymore, they switched to a dry nanofiber. The foam is only offered for motorcycles/atvs, etc under a new name, "Twin Air"....Same type of recharge oil is used, they utilize the same course foam first layer, followed by fine foam second layer. High Tack Air Filter Oil $20ish
well thats good news for the recharge kits.
just incase if they go out of business i can still buy more.
now i have to choose once again ahha
either the true flow or the airaid MIT..
only thing that stopped me from buying the true flow system was the oil thing, but i guess thats not much of a problem now haha
http://www.autopartswarehouse.com/sk...%26+Drivetrain
http://cpwstore.carpartswholesale.co...8&PN=9157&sv=0
second link is a little cheaper.
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
