| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
3 inch suspension and a 1-2 inch body lift questions
__________________
98 Toyota 4runner Limited Stupid Celebrities Gossip ISR Mod Deckplate Mod Budbuilt Skid Hella 500s Toytec 3 in suspension. 3 in body lift. 33 in Nitto Terra Grappliers Last edited by BMWToyotaMan; 03-02-2007 at 01:23 PM. |
#2 (permalink) |
no, my 1" has some running issues with 295's 2" would prolly help alot more
__________________
- Kyle Former Owner of - 1996 Sunfire Red Metallic 4Runner Limited updated 10/31/06 OEM/TRD Lift Kit #1 from Sonoran Steel with 1 Top-out spacer - Lexus GX470 rims - 295/70r17 Nitto Terra Grapplers Yukon 4.88's, E-Locked Rear, Waiting to blow up front diff #2 |
#3 (permalink) |
Andy is running about 3" suspension and 1" body and he doesn't rubb after just a little trimming if I understand correctly.
#4 (permalink) |
Heres the 99 on 325/60/18 Dick Cepeks. Its got a 3" Toytech lift and 2" RB body lift.
#5 (permalink) | |
Quote:
__________________
CJ ...<>< 03 DC TRD Tacoma 4wd with a bunch of junk. SOLD 1964 Chevy Biscayne, 230 I6, lowered, satin black, old-school legit. Just wheel the stupid thing!!! But do it responsibly, ok? My band: Road Worn Saints |
#6 (permalink) |
Take a look at steves lift kits as well. a little different than the toytec ome setup. and the 3" in hte front might pose some premature cv wear issues.
__________________
#7 (permalink) |
I've got a Daystar 2.5 OME set-up and my 285/75/16 Toyo Mt's rub a tiny bit at full crank and I have minor shaved arms and a little fender trimming too! I also have 33's on 18's that just totally drag on the upper arms so I was thinking 2in RB bl too. Good luck with your choice and post opicks I'd like to see what you came up with!
__________________
97' 4RUNNER SR5 4x4 Lift:OME 881's OME Fronts w/ TOYTEC top out spacer, OME LC Rears 2in. 4crawler BL, SS Diff drop, Custom welded drop bar Performance:Yellow Top,Custom Dual Vortex Exhaust, Magnaflow Hi-flo CAT, K&N FIPK, Diff Breather Mod Wheels & Tires:315 16x9's on MOTO METALS Lights:Silver Reverse Glow Gauges, Hella 500's Armor:Trailgear Sliders, Taco ARB "Sounds stupid. . .sign me up!" |
#8 (permalink) |
Even with the diff drop?
__________________
98 Toyota 4runner Limited Stupid Celebrities Gossip ISR Mod Deckplate Mod Budbuilt Skid Hella 500s Toytec 3 in suspension. 3 in body lift. 33 in Nitto Terra Grappliers |
#9 (permalink) |
yes. I had 2 spacers on mine for a week (instead of 1), and the extra 1/2" was very noticeable and made the cv's unhappy.
__________________
#10 (permalink) |
Damn, I was under the impression that with the diff drop in front it would be perfectly fine.
Jeff
__________________
#11 (permalink) |
CVs isnt the only problem with 2 spacers, which im running right now, it gives you hardly any down travel because at full droop, the balljoints will lay themselves on the coils, could rip a boot off the BJ too. makes steering feel loose. and I even thought about putting a third set in but im not gonna bother.
#12 (permalink) |
Well I could leave out the top out spacer so it would only be 2.5 inch and then still do the diff drop.
Jeff
__________________
#13 (permalink) |
what about just the 3" lift with diff drop? can you clear 33's w/ that?
__________________
01 Tacoma doublecab trd |
#14 (permalink) |
i had 285's on LC wheels w/ ~2.5" of susp lift. only had to trim parts of my Limited fender flares, and running board end caps when they were on. had no issues rubbing, except for full stuff in the back. if youre running the stockers, you may have rubbing issues. if you dont plan on buying new wheels, get a 1/4" spacer to clear your A arms. some have had issues with stockers on 285's...while others have not. i think Ric had 285's on stockers w/ spacers..might want to ask him about that setup. otherwise, id get 4.5" BS'd wheels, and not worry about it.
i then put on a 1.5" 4crawler BL...and of course still no rubbing in the front. jdizzy: bodylifts will NOT help clear your tires off the control arms. either spacers, shallower backspacing on your wheels, or shaved/TC/AP/Camburg arms. do the diff drop. its easy and cheap, plus it keeps your CV's in a happy working range.
__________________
sonny ------- 1998 4Runner LTD. Fabtech CO fronts, OME/Pro Comp rears, SS rear links, Revtek diff drop, oem elocker, ARB RD90, 4.88's, 315/75/16 MT/R's on FZJ-80's, Trail Gear sliders, ARB Prado Bar, 1.5" 4Crawler BL, Tundra Brakes, wabfab disco's, IPF's...satoshi'd deckplated & ISR'd. SOLD!!! new ride: 1997 FZJ80. ome/arb/bfg/etc. when clinton lied..nobody died |
#15 (permalink) |
Will I be able to keep the stock wheels or will I have rubbing problems with the upper a arms? Can 295s be run safely on a 16x7 wheel? I was thinking about keeping the stock wheels and running the wabfab spacers if necessary.
Jeff
__________________
#16 (permalink) |
i have a the toytec 3" lift and a 2" rb body lift and 34x12.50's i hade to do a little triming but it doesnt rub now
__________________
98 sr5 4runner 4cyl 5pd, 3" toytec lift, 2" Rodger Brown body lift, 34x12.5" trXus's, cragar wheels, custom HD front skidplate, 2.5" magnaflow cat back Hurlbert toyota www.hurlberttoyota.com |
#17 (permalink) |
My dilema is that I have very fresh tires on my wheels now, im not sure if I should get new rims/tires or just put new tires on the stock wheels.
If I could find some LC wheels for cheap I wouldnt mind doing that but I am on a budget. Jeff
__________________
#18 (permalink) | |
Quote:
Shop around..there seems to be deals out there. I got all of mine for $200.00 shipped (from california) to the east coast.
__________________
1999 Toyota 4Runner limited 4x4,BFG's 285/75/16's. Land Cruiser wheels. 2inch 4crawler BL, Factory Locker, 4inch ProComp front IFS lift, front LC coils on the rear with LC shocks. Original owner.18-19-mpg highway. 2007 Dodge Mega Cab 4x4, Mineral Gray, 5.9L Cummins. SMARTY JR, Mufler delete, Silencer ring MIA, SIRIUS. PICTURES OF RIGS http://community.webshots.com/user/roofgoof Owner of 1970 Pontiac GTO JUDGE |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 3 inch suspension 3 inch body lift pics anyone? | BMWToyotaMan | 95.5-2004 Tacomas & 96-2002 4Runners | 33 | 02-14-2009 02:14 PM |
| 2 inch body lift? | 95_4MuddinSr5 | 86-95 Trucks & 4Runners | 14 | 12-07-2008 02:32 AM |
| what is the best 4 inch suspension lift | slimb | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 02-03-2005 01:57 PM |
| for a 2 inch body lift? | Tacoma750 | Offroad Tech | 5 | 12-02-2004 10:18 AM |
| 4 inch suspension lift? | BigJohn | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 11-05-2002 10:30 AM |
