3 disc changer
Old 07-21-2004, 08:49 AM
kevin8714's Avatar
3 disc changer
whats the deal with toyota in-dash cd players not being able to read burned cd's too well? Is there a particular brand cd that works better, or should i just replace the whole thing?
Old 07-21-2004, 09:23 AM
r854rnr's Avatar
I most recently used philips brand cd-R discs. (I've also used Fuji and Sony blue or green discs)They work fine for me! I think if you get good quality (black is supposedly the best), and burn at a lower speed your chances of it working will improve.
However, on that note, I would replace it with an MP3 CD player. (or even an HDD MP3 player!)
Old 07-21-2004, 09:46 AM
mastacox's Avatar
If you burn a CD at high-speed (above 10x) the pits burned in the CD become shallower, easy enough for a computer to read but older CD players may not be sensitive enough to find the pits 100% accurately...
Try burning at 4x or less and see what happens.
Of course, buying a new player would fix such problems.
Old 07-21-2004, 02:51 PM
fooddude's Avatar
I had the same problem with my 3 disc changer. It pissed me off so much because i have so many burnt cd's that i just replaced it.
Old 07-21-2004, 11:08 PM
User 051420's Avatar
Try making sure you're using a CD-R and not a CD-RW or CD+RW. That might do it. I remember my stock deck played CD-R's...
Old 07-22-2004, 12:05 AM
Jason B's Avatar
The stock 3 disc changer is made by Alpine. I have the Alpine unit, which has the same exact insides as yours. Mine has been fine with burnt cd's, but then again, my burner is 4x. I just got a new pc (haven't set it up yet) that has 16x, maybe this is the reason mine works?
TheBFA
02-15-2020 06:55 AM
stanz
10-30-2015 10:33 AM
toyotasaurus
09-24-2015 03:30 PM
theBAYsic
09-16-2015 05:21 AM
Quick Reply: 3 disc changer
