2ng Gen Body Lifts?
Old 05-04-2004, 09:02 PM
mxracer0486's Avatar
2ng Gen Body Lifts?
Is there anyone on here with a 3 in body lift without any suspension lift? I want a lift but Don't have enough and wont have enough for a suspension lift for some time but I can get a 3" body lift right now, any advantages or disadvantages? Mostly PICS!
Old 05-04-2004, 09:04 PM
Scofco's Avatar
#1 disadvantage, it would look fugly.
Old 05-04-2004, 09:52 PM
Got any suspension lifts that are MAJOR cheap then?
Old 05-05-2004, 03:25 AM
Cebby's Avatar
Here we go again....
How much tire do you want to fit? What type of wheeling do you do? Is this for function or looks?
Old 05-05-2004, 08:05 AM
I would like to fit 33"s, I wheel ususally in creek beds and river beds....
Its mostly for funtcion (ie... bigger tires) But I like the looks also...
Old 05-05-2004, 09:37 AM
Cebby's Avatar
Coils to fix the rear sag (1 - 1 1/2" lift), balljoint spacers, and a 1" body lift from Roger Brown and pounding the seam at the back of the wheelwell/trimming front bumper/valence.
The coils are around $150, the BJ spacers are $120 (check the group buy for better $) and the BL is about $100. This will fit 33's on 15x8's with 3.75" - 4" of Backspacing. When you can afford it, go for longer shocks. Probably want to extend your brakelines too (I have not yet)
I'm running this setup with stock length shocks except for the BJ spacers (not installed yet) and it works good. I get a little rubbing, but I have bushwacker flares getting in the way. Keeps the center of gravity low.
Old 05-05-2004, 10:07 AM
Robinhood150's Avatar
mxracer0486, what cebby said is the standard recipe to fit 33s. Lots of people run this and can do trails such as the rubicon.
Old 05-05-2004, 11:16 AM
How much of a total lift with this be?
Old 05-05-2004, 11:36 AM
Flygtenstein's Avatar
You can go cheaper with cruiser coils, new shocks, BJ spacers and a panhard adjustor of some sort.
Perhaps 2" "over stock" in the front and 3" or so in the rear.
I have given up offering opinions on that though. The real answer is it will fit 33's. That is what I have, that is what works for me and that is what I advocate.
Old 05-06-2004, 02:02 PM
Ok so the total cost of this list will be 300-400$, do you know of any actual lift packages in that range?
If not then I guess I would just order the AllPro 1 and half inch coils... the 1 and a half inch BJ Spacers, and either a 1 or 2in body lift...
Old 05-06-2004, 02:25 PM
Oh and do the BJ Spacers increases axle angle?
Old 05-06-2004, 02:26 PM
Again:
-BJ Spacers $100
-Rancho 5009 Shocks $70
-Rancho 5167 Shocks $70
-Cruiser coils $25
-Panhard drop bracket $50
-4Crawler 1" Bodylift $100
Total: $415
Add in $20 or so bucks for beer, flapper discs for the grinder and odds or ends and you will fit 33's, be low and not have a billion dollars into your suspension.
This is what I have. It works well thus far. Ride is decent, flex is good up front and great in the rear. Lockers make the difference.
Old 05-07-2004, 08:27 AM
Ok but does the BJ Spacer hurt the axles because of increasing the angle?
Old 05-07-2004, 11:50 AM
The BJ spacers should allow less CV angle because you essentially get lift without adding height to the CV's.
That is not explained well, but they will help your angles unless you take the front way cranked even with spacers.
Old 05-07-2004, 05:24 PM
herbsblue4x4's Avatar
i was wondering what model crusier coil will fit a 95 4runner? i lookin for about 3 inches so whats my best bet Flygtenstein?
Old 05-07-2004, 05:40 PM
Cebby's Avatar
FJ80 coils. For 3" lift you'd want the "short" side coils.
Old 05-07-2004, 05:42 PM
Guest
Yoter's Avatar
Ahem........ I um uh yeah disagree
Old 05-07-2004, 06:31 PM
Fink's Avatar
I was waitin to see what you'd have to say on that one BBB...
The total cost for me to fit 33's was right around that and I have only done two things (rear coils and 1" Roger Brown BL). But the real cost was in the tires, $618.42 on those bad boys.
But I can't wait to see what they look like...I test fitted them today for the heck of it at stock height, lol, not a chance...but it looked AWESOME!
Hope it all works out for ya man!
Fink
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
09-04-2015 09:27 AM
Cabell
07-24-2015 12:14 PM
Backcountry411
07-24-2015 08:06 AM
Quick Reply: 2ng Gen Body Lifts?
