24V electric valve on a 12V truck...?
Old Oct 3, 2004 | 12:45 PM
YotaTruck1986's Avatar
Question 24V electric valve on a 12V truck...?
Does anyone know how I could run a 24V electric valve off my 12V truck? Thanks.
Old Oct 3, 2004 | 01:01 PM
4Crawler's Avatar
May or may not work, depends on how much current it takes to pull the valve open and if you can get that with 12V (or 13.8V charging). Knowing the coil resistance and the minimum operating current would give you a good idea. Usually things like relays only work down to about 3/4 of the designed voltage or so before they drop out. You could get a small DC-DC convertor (12Vin - 24Vout) from a good electronics supply place.
Old Oct 3, 2004 | 01:09 PM
I just hooked the valve up to the truck - doesn't even move. Only gives off a clicking noise. I think I'll look for a DC-DC converter. Thanks.
TACOJO
Nov 27, 2015 05:26 PM
Jdgarrison
Oct 1, 2015 05:22 PM
mund1011
Aug 16, 2015 07:10 AM
Mrhoadley
Aug 4, 2015 06:08 PM
Johntom240
7
Jul 13, 2015 12:18 AM
