231 mm Brake Upgrade PROBLEM on 01 Taco
Old 03-20-2012, 02:18 PM
Baloo's Avatar
Ran into a problem upgrading my 2001 Toyota Tacoma dbl cab to the 231 mm Tundra Brakes. The Tacoma uses a banjo fitting, which as I read through the many write-ups didn't see any mention of. In fact one writeup on t4r.org showed the 231mm install with the banjo fitting.
In either case, I am kinda stuck on what to do and wanted to see what others have done. Don't want to have to put back together and double work, so without a vehicle till I figure this out.
This is the old caliper
This is the bolt for the banjo fitting;
This the the new caliper, which generally uses a hardline fitting;
Any suggestions?
Old 03-21-2012, 01:54 AM
aowRS's Avatar
My initial thought would be to purchase a set of '96-'02 4Runner hardlines - the short section of brake line attached to the hub upright. That should solve your issue.
Andreas
Old 03-22-2012, 06:37 PM
trx125's Avatar
Seems like a seen a thread saying the person upgrading his brakes drilled out the hardline fitting just enough to allow the banjo fitting to seat in the caliper. Just a thought.
Old 03-23-2012, 05:22 AM
waskillywabbit's Avatar
Andreas
Yep.
:wabbit2:
Old 03-23-2012, 07:11 AM
JBurt's Avatar
I'd also get the 4runner hardlines. When I did mine everything fit together really nicely.
Old 03-23-2012, 08:31 AM
Staff
DeathCougar's Avatar
This is a fantastically BAD idea. High pressure hydraulic systems don't need drilled out fittings that *might* work.
Spend the few bucks and get the correct lines to do it right the first time
06-01-2021 01:51 PM
Eggslinger
06-08-2019 03:32 PM
Steven.m.paulk
07-13-2015 01:40 PM
Johntom240
7
07-13-2015 12:18 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 231 mm Brake Upgrade PROBLEM on 01 Taco
