2001 4runner SR5 nothing on # 2 ?
Old 01-27-2011, 05:26 AM
2003mikem's Avatar
Ok I have enough experience with the 20R and 22RE
What should I look for first ?
I haven’t even opened up the hood yet.
Is this a common problem ?
135 K
Old 01-27-2011, 05:45 AM
waskillywabbit's Avatar
Spark plug wires. Coil pack wires.
Did it just quit?
:wabbit2:
Old 01-27-2011, 04:06 PM
2003mikem's Avatar
i check compression. none in #2, check it wiht my scope, hole in the piston.
what can i pull a 3.4 out of uesed and put in my runner?
will and 3.4 work ?
98 and up?
4runner ? tacoma? t100 ?
thnaks
Old 01-27-2011, 04:52 PM
2003mikem's Avatar
Old 01-27-2011, 05:05 PM
mt_goat's Avatar
The basic 5VZFE engine is the same but some of the things screwed and bolted on to it changed. I'd recommend you keep all the sensors and anything electronic from your current motor. The injectors may be a different size, MAF may be different, O2 sensors, wiring, exhaust manifold...etc.
Old 01-27-2011, 05:13 PM
2003mikem's Avatar
so pretty much buy a sed 3.4 and just use the shrt block ?
keep all the thing from mine? lower intake all harness and all electrical ETC ??
Old 01-27-2011, 05:18 PM
totally a bro
Staff
vital22re's Avatar
yes, you'd be buying a used 3.4 just for the long block (Block and heads). Have your injectors cleaned professionally. I wonder if a poor spray pattern burned the hole in the block
gary4runner
09-24-2015 12:53 AM
88yodabasket
07-13-2015 01:32 PM
mengquis
07-13-2015 10:39 AM
Rkellerman
07-12-2015 08:42 AM
Quick Reply: 2001 4runner SR5 nothing on # 2 ?
