2000 4Runner limited with clunking sound: Transmission or Driveshafts?
Old 04-19-2013, 11:46 AM
Mspell's Avatar
ive got a 2000 4runner limited. Ive noticed that theres a clucking noise accociated with the trans when i put it in gear. when its in park an netural it does not make noise...
Im thinking converter possibily???
any ideas?
Thanks, Matt
Old 04-19-2013, 11:49 AM
wyoming9's Avatar
Red face
Check or have someone check your u-joints
Old 04-19-2013, 11:56 AM
Stetson_md's Avatar
[QUOTE=Mspell;52068254]ive got a 2000 4runner limited. Ive noticed that theres a clucking noise accociated with the trans when i put it in gear./QUOTE]
Its your poultry warp drive...
Old 04-19-2013, 12:11 PM
Mspell's Avatar
what is the warp drive?
Old 04-19-2013, 12:29 PM
Mspell's Avatar
i guess someone was being a smartass
Old 04-19-2013, 01:22 PM
tantacoma's Avatar
Yep, every forum is cursed by a few of those.
You might just need to have the u-joints lubed, front and rear.
Old 04-19-2013, 01:27 PM
Mspell's Avatar
could it be something in the trans? just curious ive have no shifting issues or slipping going on
Old 04-19-2013, 01:43 PM
Mspell's Avatar
was just thinking an it makes the noise when its in gear with me holding the breaks an not moving. an makes noise when im moving.... so if its making noise while im on the breaks an not moving how could it be the u joints?
Old 04-19-2013, 09:27 PM
tantacoma's Avatar
Now that you have told us that the noise occurs when its not moving, then it couldn't be the u-joints. Anything else you haven't told us about?
Old 04-19-2013, 10:07 PM
KZN185W's Avatar
is it the transmission or is it the transfer case lever that vibrates and makes a sound. if it is the transfer case lever, then there's nothing to worry about it.
<img id="ums_img_tooltip" class="UMSRatingIcon">
Old 04-20-2013, 03:35 AM
Fossilized
Staff
dropzone's Avatar
i tweeked your thread title so it is a bit more relevant to your issue.
" Help Please" clogs the search feature
Old 04-20-2013, 07:55 AM
rworegon's Avatar
Lube drive line.
Possibly broken flex plate.
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
Cplmike
07-08-2015 08:47 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 2000 4Runner limited with clunking sound: Transmission or Driveshafts?
