2000 4runner cruise control wiring diagram
I need the complete wiring diagram for the cruise control on a 2000 4runner with the v6 from the FSM. The FSM available that I have found are for the wrong year (they are for the entire range 96-02, but the wiring is from the wrong year.) Does anybody have this diagram? Worst case I will have to pay for the subscription to download it, but I want to try and avoid that for one diagram.
I have seen the FSM's for the 2002 posted - I would imagine the wiring to be very similar to the 2000 and might work depending on what level of detail you need. They have worked for me (/ given enough of a hint to figure out).
Nope, the 2002 is completely different. It is controlled by the ECU, and does not have the separate CC module. This is because of the drive-by-wire feature. I actually have the diagram for the 2000 4runner CC from alldata, but I want the FSM diagram that has the explanation of how the circuit functions. I wired it up in my truck fine, but am trying to use the on/off button on the stalk as an on/off for my main switch panel for my offroad lights (for mountain driving). I want to set it up so the main for the CC is always on. It seems that the on/off on the stalk is tied into the other functions of the stalk even though it is a separate lead off the stalk.
MMA_Alex
25
04-18-2017 05:07 AM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
Jnkml
07-06-2015 01:20 PM
