1987 4runner question:
Old 06-01-2005, 08:56 PM
TPI
TPI's Avatar
its a 4 banger with auto tranny...yea i know but what can i do?
its a slug i know but it drives fine...my question is, when o the highway it really struggles or not struggle, it makes to much effor to get to simply 70. anything over that i step on the gas and the RPM goes up to like 4 and making a "grrrrrrrrrrr" sound, what coudl this be?????? or are these auto 4runners really that slugish?
Old 06-01-2005, 09:43 PM
jimbo74's Avatar
depends... could be any number of things... if its at a relatively low rpm and then jumps with no increase, i would look to see if its torque convertor slippage.....
how is its maintenacne? tune-up? and tranny problems: hard to shift, clunks?
Old 06-01-2005, 10:12 PM
TPI
TPI's Avatar
non o, the rpm jumps only when i step on the gas...
no clunks, no slips, drives great man! just when i get on the highway it picks up fine, just when you wanna go faster and step on the gas.....rpm goes up when accelerating........
Old 06-02-2005, 12:27 AM
deathrunner's Avatar
How big are your tires?
I don't care if you say stock or if you sy 35's, I'm gonna tell you the same thing.........
GEAR LOWER
I think that is the most surefire way to get a little more grunt. That is considering you're sure the motor and tranny are functioning fine.
You could do headers, intake, exahust and piping, plus some sort of ignition upgrade...but they need to be used together to actually see and sizeable gain. There's always more aggressive cams, but then you sacrifice gas mileage and reliability. Even these thing don't really make that big a difference. So gearing, yeah, gearing.
Old 06-02-2005, 07:53 AM
TPI
TPI's Avatar
ok good point there....
its got a 3inch lift with 31's on there, wanted to put 33 but now that you mentioned it, i was wanting to add on everything you just said except headers, im in cali so smog issues are not very flexibble...
Old 06-02-2005, 10:17 AM
Wildcat_4R's Avatar
I have an '87 runner with the auto transmission. Mine acted the same exact way on the freeway when I had 31x10.50s tires...got slightly worse with 33x12.50s. After rebuilding and spending a good sum of cash on my motor my truck now accelerates when I floor it on the freeway. However, I think gearing (which I haven't done yet) would probably be a cheaper way to utilize the power you have (or don't have with these engines ). I plan on moving to 4.88s as soon as I can lick my wounds from this rebuild.
As far as headers go, I believe LC engineering's header is smog legal in Cali. Might want to check into that. I think a header is a very good investment for these motors and probably the mod that really opens up the most power. Opening up the rest of the exhaust with some 2.25" tubing and a nicer muffler certainly helps as well.
Old 06-02-2005, 12:55 PM
calisurferdude2000's Avatar
To get a little extra oomph, get a K&N drop in. Its worth the $45 or so.
Old 06-02-2005, 07:21 PM
TPI
TPI's Avatar
cool suggestions guys, yea i heard the gearing would be the case.......i will be doing the k&n for sure, once i get everything (headers,exhaust) i'll let you guys know...........but here's a picture of the slug.....link below
http://www.cardomain.com/ride/861389
oh and last note, i thought i had 31's but i have 32x11.5 on there
Old 06-05-2005, 09:56 PM
cool truck tpi
fyi, thorlye, downey, and LC engineering headers are smog legal in Cali. Just put the supplied Carb sticker under your hood.
coreyedwards7611
01-16-2016 06:38 PM
TURBOrunnerNM
07-22-2015 11:01 AM
87turboPA
07-12-2015 07:49 AM
shar
07-09-2015 12:38 PM
Cplmike
07-08-2015 08:47 PM
Quick Reply: 1987 4runner question:
