11k Uoa 1997 3.4
Old 08-17-2008, 07:53 AM
dbcx's Avatar
11k Uoa 1997 3.4
Heres the test i got back on the 4runner i bought in January.It had 196k on it when i got it ans swapped over to Amsoil 5-30XL a 7500 mile oil. I do not know what the PO ran in it. It has 207k on it now. I put 11k on this oil before i changed it. For the XL oil and the first time it was tested it looks pretty good.Thats also with a Amsoil filter. Should help prove 3k oil changes should be a thing of the past.
Old 08-17-2008, 09:04 AM
BigBallsMcFalls's Avatar
this doesn't mean anything by itself
at all
unless you have at least 5 of them at the same intervals to compare readings and wear between changes
Old 08-18-2008, 07:18 AM
dbcx's Avatar
at all
Uh, it means alot i have no water in the oil ,no fuel in oil and virtually zero engine wear and the Pb is a little high. I will do tests in the future 5 is no magic number the more the better. If its not changing no need to keep doing it at the same intervals, do them like a pop quize from time to time. By time i do 5 tests i will have put about 70k on my 4runner that will be close to 300k all with about 4-5 oil changes.
Old 08-18-2008, 07:22 AM
ozziesironmanoffroad's Avatar
i dont care what charts and such say, oil should be changed NO later than 5000, with dino, no later than 3000. also i dont trust amsoil due to it not being an approved oil. call me old fashioned, but thats how i have almost 300,000 miles on my truck on dino oil... oil change every 2500-3000 miles. if it works for you, awesome.
Old 08-18-2008, 07:31 AM
Fossilized
Staff
dropzone's Avatar
Originally Posted by dbcx
the PH is a little high.
not seeing the pH on the posted picture...what was it?
Old 08-18-2008, 07:54 AM
dbcx's Avatar
OOps should be pb(lead) hit the wrong letter. Its prolly from using regular gasoline since gas is so high.
Old 08-18-2008, 08:25 AM
mt_goat's Avatar
Why would reg unleaded gas cause high Pb?
Old 08-18-2008, 08:32 AM
dbcx's Avatar
Not sure but on bob is the oil guy it says regular gasoline can cause high readings. Or it could be bearing wear, I guess ill have to wait for the next test time and see what i get. I didnt run the flush thru it and i used the 5-30XL, i am on 5-30 ASLQT now.So i guess im waitng on test time.
Steven.m.paulk
06-07-2020 10:45 AM
primordialbeast117
12-19-2015 12:23 PM
White Stripe
10-06-2015 10:47 AM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: 11k Uoa 1997 3.4
