04 taco vibration
Old 12-02-2004, 02:55 PM
blackduck's Avatar
04 taco vibration
My 04 double cab taco will vibrate (I can feel/see it in the steering wheel and feel it in the seat) when I’m on a smooth road coasting between 30mph to 40mph (foot off the gas). Sometimes there’s a minor shake under other circumstances but no major vibration at freeway speeds. I’m fairly sure the wheels are balanced as the vibration is not worse at freeway speeds. Possible causes: driveshaft runout, bad u-joint, bad motor mounts, warped rotor/drum, tire/rim out of round, rack & pinion issues, stealership gremlins…anyone know how to do an exorcism?
Old 12-02-2004, 04:29 PM
humanoid's Avatar
Might wanna check the torque on the lugs (about 85 ft/lbs) and maybe grease the drive shaft along with the U-joints.
Old 12-02-2004, 06:25 PM
02SE's Avatar
One thing you might check is the carrier bearing on the rear driveshaft. One of the local incompetent dealers (Mark Miller Toyota SLC, UT.) couldn't figure it out.
I went to a driveline shop, and they diagnosed it immediately. This was on a '93 Extra-cab 4x4.
Old 12-02-2004, 06:46 PM
Schuey2002's Avatar
You might also have a wheel that lost a wheel weight, too.
My worthless .02 cents..
Old 12-03-2004, 08:44 AM
blackduck's Avatar
I was just at Mark Miller last night. They said "It feels normal" and "The TRD makes this a hard riding truck". I havent driven other Dcab Tacos so I dont have anything to make a comparison...yet. Something doesnt smell right though...
Greased driveshaft zerks last month. I'll break out the torque wrench this weekend and look at the wheels for missing weights.
hiluxinargentina
09-30-2015 05:51 PM
JPV
09-28-2015 03:15 PM
Odin
09-26-2015 06:56 PM
Toys4parts
09-26-2015 01:56 PM
4Xtruck
16
09-24-2015 09:38 AM
Quick Reply: 04 taco vibration
