01 ISR mod - CEL now on
Old 03-10-2007, 12:11 PM
Baloo's Avatar
I did the ISR mod found here. Now my check engine light is on. I just pulled the fuse and have checked and rechecked all teh hoses and everything seems fine. Any ideas?
Old 03-10-2007, 12:16 PM
MTL_4runner's Avatar
You need to get the codes read so we can help you, just knowing there's a CEL doesn't give us any info.
Old 03-10-2007, 01:36 PM
Baloo's Avatar
You're right, however...
Did the ISR and Deckplate mods. Changed the plugs and, of course, the air filter at the same time. Started it up and the CEL was on. Pulled the EFT fuse and waited a bit. Put the fuse back in and still had the CEL.
Posted here as I left the shop to check what the code was. On my way back to the house to pick up the reader, CEL went off. Guess it just took a bit for the taco to realize that having your sinuses clear doesn't mean there's a problem.
Old 03-10-2007, 02:27 PM
It's not uncommon for it to throw a CEL after doing the deckplate, ISR or even cleaning the MAF. Just reset and drive until it comes on again and then read the codes.
TheBFA
02-15-2020 06:55 AM
oldblue
09-28-2015 04:07 PM
charlie_fong
09-27-2015 10:06 PM
Draven023
09-26-2015 12:41 PM
Project90
09-24-2015 11:40 PM
Quick Reply: 01 ISR mod - CEL now on
