Speedcrazy's 94 Pickup Evolution
#61
Think i forgot to mention I'm dropping the truck off at the muffler shop in the morning for a new set of tailpipes.
This being the case i need to decide where i want them to exit.
As to options 2 and 3, i'm not really sure. The advantage of 3 is that changing bumper wont mess with it.
At this point i am going with 3 but i am willing to listen to any advice or suggestions.
- Single Side.
- Split - out the back.
- Split - behind the tires.
#62
Thanks, apreciate it. I like the flat black look, but it has a number of qualities that turn me off; namely hot, always looks dirty, no hard coat, everyone and their uncle paints their truck flat black around here. I want something completely me.
Big three? Isn't that both battery wires and the grounds? I just did all those.
Link for the locks. I have it around here somewhere. Toyota Pickup Truck 1989-1995 Ignition & 2 Door Lock Cylinders with New Keys (S30020) : Amazon.com : Automotive
Price has gone up since i ordered but still a good deal. I am happy with them, but i have only had them a few weeks.
#63
thanks for the link, the big three is grounds battery and running a bigger alt wire for your charging system, the original in the harness is small and usually crumbles to nothing, another good upgrade look into the jaguar alt upgrade, you change the front pull to the 22re style pulley and its straight plug and play 120amp, no modifications other than pulley
So where does the alt wire run to/from? I know that would be a good idea as my battery light blinks when ever i turn on my lights.
Jaguar alt? Just looked up the thread. I will have to see about that, jag or not it probably could do with an upgrade before i start adding lights and such, especially if i lay my hands on a winch.
UPDATE:
Got tailpipes on today. Will post pics once it stops raining.
Also; replacing the battery cables and grounds appears to have solved my tps an knock sensor issuers. Even after driving around town for 20 minutes or so and then home the cel did not come back on.
#64
No problem, glad to help.
UPDATE:
UPDATE:
#65
Quoting so i can note progress and add things.
The change i mention on the fuse box and such plan i mentioned is as follows, and please tell me if this is silly or infeasible.
What i was thinking is a dual battery setup, where both are hooked up, charging and running stuff while the truck is running, but when the ignition is turned off any hot accessories are run from one isolated battery to prevent a dead truck. It would require building something like this http://www.12voltguy.com/DUAL-BATTERY-KIT.html
Obviously this require a bit of rewiring and relocating, hence putting my fuse box plans on hold for now.
The idea behind this idea(does that work, idea behind the idea?) is that i want to be able to park and run music, lights, oba, or whatever without having to worry about draining the battery and being stranded.
Basic summary 2 batteries, one is isolated after the ignition is turned off. This is not an immediate plan i just want to make sure that things i do now won't preclude it. Hence rethinking the where and how i want to hook up the aux fuse box. I may make a separate thread for working this one out so as not to clutter this one.
The to do list(to be completed in roughly this order):
- Get down to the muffler shop and have some tail pipes made. Done!
- Weld on my shock mounts. Just ordered a set of these: http://www.lowrangeoffroad.com/index...ck-mounts.html I know i could have had some one make me some but they are cheap so i figured it will save me time and frustration and i will know they are done right. Welding on Monday!
- Choose order and install shocks once my mounts are in. can't wait to get rid of that horrendous rear end walk. Waiting on shock mounts to be welded in.
- Redo a bunch of my wiring: 2 grounds are missing(block and battery), knock sensor circuit may be bad(its definitely brittle so i will just go ahead and replace it and hope that fixes the problem). Also need an aux fuse panel for amps and lights etc that i hope to install. And if i have time i would like to do my main battery lines as they are slightly corroded and too short too route out of the way. Grounds replaced, battery lines replaced. This plan has changed slightly as far as the fuse box and aux battery goes. I have added the alt wire to the list needing done, as the wire is about wore out and the ground sucks. Pics will be up in the next post along with tailpipe pics.
- Spec out and start buying parts for my audio system(i know i ought to finish the exterior first but i have a long road trip coming up and i need my tunes). Nothing happened yet, i am reticent to spend money on tunes when other things need work. Probably just gonna get a dirt cheap radio and run the stock speakers for now(if they even work..)
- Fix speedometer. Still stumped on this one.. i can unplug the vss and not get a cel so i think something is screwed.
#66
Okay here are the pics i promised.
New tailpipes:
Driver Side
Pass Side
Underneath, i think he left enough room to put a full-size spare under there if i find some mounting hardware.
And the alternator wiring i mentioned earlier:
Don't know if you noticed, but my alt wire is about worn through. And i wondered why my battery light flashes. And the ground is sketch.
So i obviously need to do some work on that. Not sure exactly what yet but we will see.
As for the tail pipes, not sure if i like the new sound yet, but it is definitely quieter, i can actually hear myself think now. Do i need to paint them with something to stop rust?
New tailpipes:
Driver Side
Pass Side
#68
I am researching what to do with the alt wiring for sure. I think i will bypass the harness and go to the battery. But i need to read some more before i make up my mind.
#69
Vid coming =p
I am having trouble figuring out how to rewire the alt. Most of the info i can find suggests two wires should be bolted to the stud on the top of the alt. I only have one, a big(about 8ga i think) white one.
Now that being said, i cant decide, run the new wire to the fuse box or run it straight to the battery, with an inline fuse? I am thinking keep going through the fuse box just for simplicity's sake. But i want to hear the pros and cons.
I also need to know what gauge wire i should use? Stick with 8ga or upgrade for future possibilities(i do want to do dual batteries so that might mean a bigger alt, but at the distance of cable i will be running i don't think it will make too much difference?).
#70
Okay, i got under the hood, and toyota threw me a curve ball right off the bat...
the alt wire goes approximately 3 feet before terminating in a black box behind the air box.
This is it closed with the alt end already removed.
Open. The alt side wire goes in the open slot and bolts over the top of that other wire.
Is that stock? Either way i'm running out of time, besides being out of my depth deciding fuse box or inline and all the circuits, so unless someone posts before i finish my breather i am just going to replace this section and leave everything else stock for now.
#71
Truck is out for the count
So i replaced the wire from the alt to the + box thingy, then loomed it and taped it all up nice and pretty before slapping the air box back in and firing her up.
And ...... the alt wont charge!!!
Now the only thing i changed is that where the stock wiring had a weird bunny eared ring terminal i substituted a standard one as i couldn't find one like it.
Apparently those ears are important...
At least that's all i can figure, i pulled the air box back off and all my connections are solid.
Any ideas?
Any ideas?
#72
Well those bunny ears are not the issue, would have been surprised if they were, but i can hope right?
The battery was dead this morning so i have a short somewhere and now i am confused stressed and rushing to figure this out before work tomorrow. Not a good combination. And to top things off i can't figure out how to get my multimeter to work.
If anyone has any ideas please head over to this thread
https://www.yotatech.com/forums/f116...oblems-270690/
And yes the exhaust vid is on the way, but it does kinda require a running truck to make =p
#73
to answer your question about the black box, yes that is stock. usually the wire from the alt to that box corrodes from the extreme heat the exhaust gives off. i suggest keeping that little junction box, i believe from there that wire goes to the white wire on the fusible link, if u didn't disconnect the battery when u were mucking with the wires you can A) blow that fuse or B) blow the alt. if you get sparks flying from your alt at any time you run the risk of blowing it, I made that mistake once i will never do it again.
#74
So now i am looking for plug-n-play alt upgrades. but i gotta run, thanks for the info.
#75
Look up the jaguar alt upgrade, its completely plug and play all you have to do is change the pulley on it, has 120 amp output, much better for accesories
#76
#77
And it $200... not so sure on that.
#79
I ordered a 70 amp alt for a 4runner as i don't have any more time to waste. Should be at the store by 3 so i will hopefully be up and running this afternoon.
Would have liked to go bigger, but this will do for now.
#80
you can find jaguar alts in junkyards for like 30 or 40 bucks usually just need a cleaning, you also cna take the alt to a shop or even a wal mart and ask their shop to take the pulley off, cost you 5 bucks if anything at all
