John101477's 1986 4Runner Build-Up Thread
hey everyone sorta new here and still gathering info for my work in progress 4runner. unfortunately it is an automatic to start with but oh well. so here is what i have done with it and kinda the direction i am going. first off after $1400 worth of fix-it bills, it is finally legal and most everything works and of course part of the $1400 was new fluids everywhere. So I bought a Trail Gear bumper and a Smitty Built RC8 winch (so far i love it). now i have added some new tires Toyo MT 31x10.5/ 15 which i love as well. I do not plan to raise the rig at all but i have added an add a leaf to the rear to rid myself of the saggy butt syndrome. My direction here is basically a go anywhere do most anything type of rig that is still comfy to be in. I do alot of landscape photography and hunting so while i won't be doing alot of rock crawling, i will be in the rocks alot. I had thought about a swinging rear tire carrier but am leaning towards a roof rack instead. my problem is that i can't find any type of kits for this specific to my year? along with this i am also doing a mild audio system ( mild for me as i used to install major systems when i was younger). maybe some role out boxes in the rear? a camera holder in the front for quick grab? and a air compressor. I would also like to add electric lockers but still reading up on them, we'll see. anyways your thoughts and experiences would be apriciated.
ok here is my rig
https://www.yotatech.com/attachment....1&d=1236530410
https://www.yotatech.com/attachment....1&d=1236530554
and the root of all evil!!!
https://www.yotatech.com/attachment....1&d=1236533214
just trying againhttps://www.yotatech.com/attachment.php?attachmentid=728https://www.yotatech.com/attachment.php?attachmentid=72888&stc=1&d=12365334 1087&stc=1&d=1236533366
ok there are the pics. and this last one is the one thing on the truck driving me crazy right now
https://www.yotatech.com/attachment....1&d=1236533492
Looks good! Regarding the roof rack and swing out spare carrier, shouldn't you be able to fit a 31" tire in the stock spare tire holder? A spare on the roof will decrease your mpg, and a swing out tire carrier will obstruct your rear view mirror. Obviously, both aren't huge deals, since so many people run these setups.
Regarding lockers...I would say just wheel until you feel that you need them. From what you've described, you might do fine with open diffs. You'd be surprised what a stock 4runner with good tires can do.
That winch is a good idea since I'm guessing that you probably do a lot of your photography alone and in the early morning when the trails don't have many other people on them
lockers- I only thought of lockers to get into some of the worst places, but wanted to do electric cause my wife may drive the rig once in a while and if it is wet on the road, i don't want the lockers engaged
I am alone alot so when I am out and about crossing the ponderossa or headed cross the back of shasta, lassen, or tahoe, I want to be safe. the winch was a must. I have even set up an emergency box in the back that holds all the "boy scout" type things.
After 2 years of sitting, it is finnally starting to look like a capable rig..
Thanks for posting the picture of the trail gear front bumper, im ordering one for the front of my 86 4Runner in a couple of weeks. My 86 4Runner looks just like yours, but i have 14'' inches of lift and 37'' tires, Detroit locker in the rear and an ARB up front, duel cases and 4.88 gears.
deff go elocker in the rear or air lockers front and rear.. i would go dual lockers just case you wheel alone alot.. better to have a more capable truck.. nice truck..
to find a truck with that little rust up here would be unheard of..a guy who came and looked at my 93 today couldnt believe how clean the truck was.. mostly they are shot...
My 4Runner is being built at my cousins house in Garden Valley right now, but its almost done. I do want to take it on the rubicon a couple of times before i move to Idaho next year. My cousin also has an 86 4Runner with Dana 60`s front and rear with 39'' tires and as much lift as i have on my runner, and he can go just about anywere he wants with out getting stuck. I forgot to mention that my 4Runner also has a solid axle up front.
Rock Crawlers moto " lift as much as you need but as little as possible"
Nice looking rig.
Since you mentioned a lot of snow I'd advise against putting the spare under the rig in the factory location. In fact you could probably cut all the spare tire mount hardware out and use that area for some on board air. If you have the ability to air back up after a run into the hills then airing down for traction opens up a whole new way to wheel. You'll get farther with flatter tires, trust me on this one. Get a roof rack for the spare or since you don't sound like you want to run anything larger than the 31's you have you could strap it down in the cargo area or get a roll bar mounted spare carrier.
I still think a roof rack would be a good idea for extra stuff (i.e. shovel/hi lift jack/weather proof box with sleeping bags etc.) and it's a nice place to mount a couple of lights in case you end up getting back later than expected.
Lockers...... well that's one heck of a discussion right there. You mentioned that the wife drives it sometimes so I'm going to recommend against an automatic (lunchbox) locker like the Aussie since it takes some getting used to and is a bear in the ice when you aren't used to it. Go with something selectable like an ARB. If you decide to go the route of on board air like I mentioned above you'll already have an air source for the ARB. Or you could try to source an e-locker axle and swap in the entire thing although you'll need to make sure the gearing matches. Since you have an automatic you probably have either 4.56's or 4.88's.
Good luck and be safe out there.
oh I'm always safe. The onboard air was an idea as well and thats exactly where i was gonna put it if i took out the spare. I had also thought of the roof rack as a light mount lol. I hate those light bars that they sell for over the cab....
I have not really researched the lockers enough to make a decision, but I do want something i can turn on and off for the wifey. I was checkin out ur rig as well it looks like a great , clean, rig.
I hate to say this man but if you go to the RUB with 17in of lift on 39's youi better have a tow truck handy. sounds like a beauti of a rig though. i like the solid conversions, but unless your running low with no fenders and spread out tall is not the way to go.
Nice rig. I like your train of thought on the build. I'm doing a major build on my '86, and in some respects, I wish I had toned it down a lot. Ah well, we do a lot of rockcrawling over here in AZ so it certainly won't go to waste. On your build I would certainly consider going ARB both front and rear. My reasoning for this is that once you get into selectable lockers, you've already bought off on a fairly high price tag. A portion of that price tag is the air source for the ARB if you go that route. You have to get something whether you have one locker or two so the second locker is really only the cost of the actual locker. If you do this, you have premier lockers both front and rear with total control by you. You also already have your air souce if you get the full size ARB compressor. I've heard reports that it is slow, but at least it is there, all the time, under hood, and doesn't have to take up additional space in your cargo area. I only have one ARB on my build and opted for the mini compressor. I may regret that but we shall see. I'm not a fan of retro fitting the e locker in our rigs as it is quite a bit of fab work and the outcome is not certain of success. If you have a lot of fab skills and fab tools then maybe it's a different story. Here is a link to give you an idea of what is involved.
http://www.sonoransteel.com/phong/re...ic_locker.html
Best of luck with your build.
Myyota, don't take this as tryin to ruffle your feathers but with 17 in of lift it is not the getting stuck that ur up against. It is the roleovers. Their are parts of the rubicon that would be impossible for a rig of that size. The rig that you discribe sounds like one heck of a mud slinger but in the rocks and steep country, it just won't cut it. It's to tall.
