FS[SouthCent]: 94 4runner part out SouthCen Texas
Parting the rest of my parts truck out. Located San Antonio TX. truck has 240k 4:88
Shipping: I like to use flat rate USPS, it keeps it all easy,
Small - 6.00$
Medium - 12.00$
Large - 16.00$
everything else that wont fit in those boxes, Send me your address for quotes
Not listed...let me know what you need. Nothing set in stone. Feel free to make an offer, worst I can say is no.
Power side mirrors 25$ each
Frnt Signal Light housing - 25 each
Chrome front Grille - 45$
Headlights - 30$ Each
Throttle and TPS sensor $50
Valve covers - 40$
Coil and ignitor $50
Injectors - 75$
wiper motor - 50
Distributor 40$
Lower Timing belt cover/fan mount - 15
Hydraulic tensioner - 15
Timing belt sprockets - 10 each
Door pannels 35 each
window/mirror switch - 25$
Window switch pasenger side - 10$
Dash bezel 40
Dash top pad 60
Dash board structure 60
Ash trey/cig lighter/radio lower dash piece 35
Glove box 35
Alternator - 50$
AC compressor - 50$
Starter 50$
Front rotors and hubs with bearings 30 Each
Rear heater core - 45$
Front skid - 25$
fan shroud - 15
Brake Master cylinder 25$
Power steering pump - 40
Radiator fan - 20
Factory amp -10
Ignition switch/door locks/tailgate lock/ 1 key 50$
Fuel rails - 30$ (rails and fuel lines only)
license plate light housings - 15$ each
Front 4:88 - 75$
seat belt assemblies - 40$ each
Rear seats - 35$ each
SOLD ITEMS:
Tranny T-case
Rear 3rd 4:88
Radio
Water pump
Timing idler pulleys
Rims tires
Air meter
Steering column
Cylinder heads.
Brake booster
gauge cluster
rear view mirror
center console
shifter assembly
radiator
fan clutch
Text email or PM me. Texting or calling is fastest
830-446-12zero1
z.vanallen@hotmail.com
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG]
[/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG]
[/IMG]
[IMG][/IMG]
[IMG][/IMG]
Small - 6.00$
Medium - 12.00$
Large - 16.00$
Valve covers - 40$
Injectors - 75$
wiper motor - 50
Distributor 40$
Dash bezel 40
Dash top pad 60
Glove box 35
Alternator - 50$
AC compressor - 50$
Starter 50$
Front skid - 25$
fan shroud - 15
Radiator fan - 20
Factory amp -10
Front 4:88 - 75$
SOLD ITEMS:
Tranny T-case
Rear 3rd 4:88
Radio
Water pump
Rims tires
Air meter
Steering column
Cylinder heads.
Brake booster
gauge cluster
rear view mirror
center console
shifter assembly
radiator
fan clutch
830-446-12zero1
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG]
[/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG]
[/IMG]
[IMG][/IMG]
[IMG][/IMG]
Vargntucson
07-04-2015 12:15 PM
