Ford 2wd: I'm looking for input
#43
Thanks Terry for the thread clean-up.
Thanks guys for trying to educate Josh on his rig.
#44
Staff
Your Welcome. He was determined to push the limits.
You other guys were giving some great information, I was in the older Fords and forget when they stopped using the I beam. It has been a while since I have messed with Fords. Was hoping it would turn into a great thread on Fords as I like all makes and models.
I changed his comments, as he was way out of bounds of what he was saying. Thanks for not getting stooping to his standards.
#46
You may want to consider gettin' a 96 or older ford with the ttb (tib) front suspension. They handle jumping waaaayyy better than my 97 or 99 f150 4x4's could dream of. My old rangers and my 96 bronco were great for bouncing through the woods/jumping frost heaves.
As for the trans in your truck (4r70w 4 spees auto), i've had 3 of them in 3 different vehicles and i can tell you they can take a whoopin'! Only time i was scared of cooking one was towing beyond my 99's towing capacity (has a 5.4 in it). Make sure it's got fluid and it aint bad/burnt fluid.
Rear axle, 8.8 is a good unit. Or find a limited slip 8.8 out of an fx4 with a 4.6.
If you want to hang onto this truck, invest in a good, long arm front suspension for the front. That short arm suspension will pound the hell outta your spine (if you're out jumping it). It may feel soft and comfy around town, but it'll abuse your body once you leave pavement.
#47
I'm looking to do some small stuff to my 1997 ford f150 xlt 2wd pickup and I need a little I've been around rock crawlers from polaris rzr,s to rock bouncers so I no the limitations to 2wd I just don't know if it stupid to do what I want to do
My truck is a 1997 ford f150 2door 8FT bed with a 4.6 liter v8....the motor is my consern I'm not sure if it's to heavy or something it's a cast iron block with aluminium heads so I just need help
LittleUgly
15
01-02-2020 01:30 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
