Stock 91 4runner 4x4 maximum tire size on 15 in factory rim? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Tires & Wheels
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-02-2009, 08:02 PM   #1 (permalink)
djkron's Avatar
I have looked and looked and cannot find what the maximum tire size would be for my truck, and I need help, I currently have 31x10.5x 15 is this as big as i can go? truck is stock.
__________________
1991 toyota 4runner
3.0l
5spd
4x4
sr5
Hamilton ontario canada
150 000 KM
djkron is offline
Old 09-02-2009, 09:01 PM   #2 (permalink)
Tubbyfatty's Avatar
Send a message via AIM to Tubbyfatty
you can go as big as you want. You just need to make sure your truck can handle them.
__________________
94 4runner / SR5 / 3vz-e / 5spd / 4x4 (duh) / Mudcat EXT 30x 9.5R15s / Marlin Crawler HD Clutch / ISR / Hella 700FFs 100w bulbs / 2 10'' JBL subs / ported sub box / kicker mono amp / Pioneer DEH-P490IB / sitting 1-1.5'' below factory, thanks butt sag...
Tubbyfatty is offline
Old 09-02-2009, 09:09 PM   #3 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
If you can run a 31x10.5x15 and it doesn't rub at all, even with the steering turned full left or right and you a bump large enough to fully compress the suspension, then maybe you can go wider or taller a 0.5" or so. Basically, you can go as big as you can so long as it doesn't rub. But even then you can go bigger if you don't mind the rubbing.
So that is a subjective question.
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 09-02-2009, 09:30 PM   #4 (permalink)
tc
tc's Avatar
In terms of what will fit on the rim ... any diameter as long as it's 12.5 or narrower.
As far as what the tallest tire you can fit on your truck with no rubbing using the stock rims - 33x10.50
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 09-02-2009, 09:40 PM   #5 (permalink)
Matt90V6SR5's Avatar
Im going with pirelli scorpion ATR size 31X10.5R15......90 4Runner V6 5SPD 4X4.
Matt90V6SR5 is offline
Old 09-02-2009, 10:12 PM   #6 (permalink)
JeEVeS's Avatar
34 9.5 15 super swamper tsl. will rub a little up front. i have a 94 runner, so my rear axle is 1/2" wider i belive. rears tuck inside fender perfectly. not very driveable.
32 11.5 16 snow wheels. in my opinion a very good choice for a stock ifs toyota. never heard mine rub (with stock suspension). look really nice as far as filling the wheel well without being in the way.
also in my opinion a 31 astheticly looks to small on a runner. very driveable though, i have a 31 10.5 for daily (summer) driving.
__________________
scheme'n
1994 4Runner SR5 22RE R151f hand built on the street. Now cruising at .4mph
Member since 08 but it took me 3 years to come up with an unasked question
Jeni
JeEVeS is offline
Old 09-03-2009, 02:24 AM   #7 (permalink)
TNRabbit's Avatar
Realize that the larger the tire (both in diameter and width), the crappier your fuel mileage will get. Also, taller tires will KILL your passing/acceleration and ability to hold speed going up a hill.
__________________
TNRabbit
Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 17" 2006 Alloy Wheels, 228k miles, AISIN Hub Swap
3.0 Rebuild Thread: http://www.yotatech.com/f116/crap-he...-ghost-108156/
Like the good book says "you can give a man a Toyota and he will wheel for a year, you can teach a man Toyota and he will wheel for a lifetime."
yotatech 3:16
TNRabbit is offline
Old 09-03-2009, 08:53 AM   #8 (permalink)
Levis Pennae's Avatar
I have a 31 inch tire on my Pick-Up, and I only noticed slight rubbing on full turn and full compression.
__________________
1991 Pickup, Standard Cab and Bed, 31" A/T tires, SR5 Seats, K&N Filter, Pacesetter High-Flow Catalytic Converter, Pacesetter Performance Cat-Back
If you find that I start talking out of my a$$, please feel free to introduce it to your boot.
Levis Pennae is offline
Old 09-03-2009, 11:14 AM   #9 (permalink)
tc
tc's Avatar
Quote:
Yeah, I had a set of those too, and don't really consider them an option for a truck that sees pavement. I had to trim a little, and they would rub pretty good under offroad suspension travel.
__________________
tc is offline
Old 09-03-2009, 07:05 PM   #10 (permalink)
djkron's Avatar
Thanks Tc, you answered my question perfectly, I live in canada and need new snow tires so I wanted to know how wide i could go for maximum traction. thanks!!! any other advice for a mud/snow tire purchase?
__________________
1991 toyota 4runner
3.0l
5spd
4x4
sr5
150 000 KM
djkron is offline
Old 09-03-2009, 07:06 PM   #11 (permalink)
djkron's Avatar
I just dont want my new rubber gettin chewed up, it is mostly a city truck that sees the off road a couple of time a year. I have a set of tires for the summer to beat on, I just want someones opinion on the best suited tire and size, more traction the better!!!!
__________________
1991 toyota 4runner
3.0l
5spd
4x4
sr5
150 000 KM
djkron is offline
Old 09-03-2009, 07:30 PM   #12 (permalink)
tc
tc's Avatar
Skinnier tires are better for the mud/snow around here.
__________________
tc is offline
Old 09-03-2009, 07:51 PM   #13 (permalink)
Yup yup. Got snow- go skinny. You want to cut through the snow and contact the ground, not float on ice.
__________________
Old 09-03-2009, 10:48 PM   #14 (permalink)
Hey tc Im in firestone,whats up?
Old 09-04-2009, 04:29 AM   #15 (permalink)
I've got 33x10.5 on my stck 95 4Runner, no rub at all, looks great, and lots of fun in the mud.
__________________
1995 4Runner SR5, V6, Auto, 4.88s
Upgrades/mods so far:
Various mechanical repairs, removed wheel well trim and running boards, Moog variable rate rear coils, BFG 33x10.5x15 MT KM2s, wheels painted black, Sony CD/MP3 player w/USB input, 6 ½” front speakers.
To come:
Hella 500FFs, Aisin manual hubs, Sonoran Steel IFS brace, Addicted Offroad front bumper, rear bumper, sliders, Yakima Load Warrior & various mounts, snorkel, some kind of idler arm brace, rear locker (not sure which yet).
nevermore1701 is offline
Tags
02, 15in, 1991, 4runner, 91, 95, cal, factory, maximum, rims, size, stock, tire, toyota, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
