restoring late 90's Tacoma wheels
Old 08-26-2012, 11:28 AM
Yamiryder's Avatar
I figured I'd make a post about the wheels I got recently and what I did to them. I got them from a lady I work with, but the catch was I only got three mounted on some goodyears. They were oxidized really badly, so I sanded them down and wire wheeled them. I used the wire wheel, then 150 grit, then 400, and finally 800; all wet sanding. I paid $40 for the 3 wheels and tires and then bought another
wheel of eBay for $70.
This is after sanding before paint:
For paint I used dupli color silver wheel paint, 3 light coats. Then I used the clear coat from dupli color, 2 coats.
Pretty happy with how they turned out!
Old 08-27-2012, 03:22 AM
rokblok's Avatar
They look great! Excellent work!
Old 08-27-2012, 06:11 AM
Yamiryder's Avatar
Thanks! I wasn't sure how close the silver would be to what I wanted but its a perfect match.
Old 08-31-2012, 11:09 PM
Luvmeye22re's Avatar
NICE! I just scored a set of Taco wheels and they look pretty rough. Did you use a wire wheel on your grinder or get one of those smaller ones that fit a drill? I'm probably going to strip the tires off mine and get the valve core out out first and go black with mine.
Old 09-01-2012, 06:09 AM
Yamiryder's Avatar
I just used one that fits in a drill. I also got little 3m sanding disks at advance auto that fit in a drill that helped some. I know I had to do a lot of hand sanding though....
Old 09-02-2012, 08:20 AM
lilyota1's Avatar
Well done.
Old 09-06-2012, 03:53 AM
Yamiryder's Avatar
Originally Posted by lilyota1
Well done.
thanks!
Old 02-04-2014, 07:38 AM
gdutch's Avatar
Sorry to resurrect this old thread, but did you do anything with the center caps? I've got the same wheels and they could use some TLC, but the caps are the worst part.
Old 03-15-2014, 09:46 PM
MauiJim's Avatar
I refinished some center caps in the same way- clean them well, scuff, and spray with Duplicolor. Turned out just like OEM, they look really great.
Flying91
45
04-11-2024 04:39 PM
coffey50
07-28-2015 10:55 AM
94yotaMI
07-21-2015 05:47 AM
Yotoder865
07-09-2015 07:51 PM
Quick Reply: restoring late 90's Tacoma wheels
