Sign in using an external account
| Tires & Wheels Anything about tires and wheels Sponsored by: |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
Staff
Factory Recommended Tire Pressure 285/75R16 BFG M/T
__________________
2011 Tacoma DCSB PreRunner TRD Off-Road 2007 Tacoma DC TRD Sport - SOLD 1985 4Runner SR5 "Ratchet" - SOLD 1999 4Runner Highlander - SOLD 1995 4Runner SR5 V6 - SOLD YotaTech Store |
#3 (permalink) |
Guest
Personal
Sales Rating: (0)
when i ran my at's at 40, the ride was absolutely atrocious
shame they dont have that calculator on the web |
#4 (permalink) |
Personal
Sales Rating: (0)
I'd hate to question the tire mfgr but... They are right that a bigger tire holds more air, volume. Also a larger tire with more volume will hold more weight. They proved that also by saying that the bfg with 35psi will carry 2130#. If you need to increase your safe laod carrying capasity then a larger tire with a higher max psi will raise your safety margins. It has been my experience that a larger tire will require less air than a smaller tire to carry the same amount weight. I would call them back and ask them what psi should you run to match the stock psi/capasity (29psi/1720#) Doing the chalk method you can check if your footprint is ridding flat.
__________________
2000 4Runner Sport, 3.4L, 5 Speed, Custom Front Winch Bumper, Custom rear bumper w/tire carrier, Yokahama AT/S LT265/75R16, Bilstein Shocks, Poly Rack Mounts, ToyTec Coilovers built on Bilstein 2450s in front and OME 891s w/10mm packers out back. ToyTec Panhard Bar Drop. SS Front Diff Drop. Home-built 2x2 Sliders. Full IFS/Belly/Fuel tank skidplates, ARB rear locker, OBA, CO2 See My 4Runner! 3rd gen 4runner fuel tank skidplate http://lilskipsoffroad.wordpress.com/ Thread link to YT sales |
#5 (permalink) |
Personal
Sales Rating: (0)
I always do the chalk test, inflate the tire to about 10% less than the total and draw a line with chalk across the tire. Then drive a bit in a straight line and see if the chalk wears evenly, if not adjust your pressure.
I have found its about 10-12% less than the recommended max psi...
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks. Be polite. Be professional. But, have a plan to kill everyone you meet. |
#6 (permalink) | |
Vendor
Sales Rating: (0)
Quote:
tempature and pressure however are closely related... pV = nRT i don't know why this sticks in my head so well... Anyway.. from a cold morning tire pressure to the significant heat generated by friction from driving - nit picking between a few psi is kinda silly... |
#7 (permalink) |
Personal
Sales Rating: (0)
I think for that size thats a little low, I feel the lower is better if you do alot of driving on dirt roads etc. But out on the highway I run like 40-45 lbs.It all depends on what your hauling and how you like your ride. I noticed my 285 BFG AT's really buldge at the side walls at 35 lbs. and really look low. I guess it just depends on wear too. Keep an eye on em' and adj. as needed.
#8 (permalink) |
Personal
Sales Rating: (0)
The big fat tires on ATVs only have 3-5psi and hold alot of weight. The 6x6 can carry 1000# in the rear bed.
__________________
#9 (permalink) |
Personal
Sales Rating: (0)
I've heard so much damn stuff about tire pressure, its rediculous.
But, the last 3 people have told me to run at 35psi. This is coming from: 1) A mom and pop tire company 2) A retired auto-shop teacher 3) A full time professional mechanic at a dealership Now, hearing this from the manufacturer makes me think I'll stay at about 35 psi.
__________________
1997 4x4 Limited 4Runner 3.4L - ARB Tacoma Bumper, Icon's, OME 890's, FZJ-80 Wheels, E-Locker, 285/75/R16 BFG KO's. 1996 4x4 3.4L SR5 4Runner -- SOLD 6" IFS lift * Front: Tundra TRD Coils/Bilstein 5125 * Rear: FJ80 Shocks/Coils * ARB Bull Bar + Warn M8000 * 35" MTR's * HID's * OBA * E-locked! |
#10 (permalink) |
Personal
Sales Rating: (0)
35-40 IMO...I run my MT/R's at 40 and they do just fine.
__________________
'98 K1500: Stock on 265 BFG AT's '93 CR125: FMF Pipe and Silencer Buggy build coming soon... |
#11 (permalink) |
Personal
Sales Rating: (0)
Something else to think about. Two bicycles, one a road bike and the other a mtn bike. The road bike with the 1" wide tire runns with 125 psi the mtb with 2.25" wide tires runs 35 psi. The volume is much greater in the mtb tire carrying the same weight.
Also the lower psi you have in a vehicle tire allows that tire to roll in corners much easier alowing the shoulder of the tire to wear faster.
__________________
#12 (permalink) |
Personal
Sales Rating: (0)
I run my 285 BFG MT's at about 45psi. I also find that mine really buldge at the side walls at 30-35 lbs. Also I find that if I leave them at 30lbs and go for a long ride, the sidwalls actually seem to get hot. I spoke to someone at toyota and they said that this is from the sidewalls flexing and that the heat can lead to a blow out. TRUE?? At 45lbs they do not seem to get as hot. It reads MAX 65PSI on my sidewalls.
__________________
2000 4Runner Limited 120K, ELocker, OME shocks and springs 1991 4Runner V6 Sr5, 2" Susp. Lift, 33" BFG MT |
#13 (permalink) |
Personal
Sales Rating: (0)
Staff
[OP]
I have almost no buldge at the sidewalls, a little buldge is okay...it just means the tire is touching the ground at the sidewalls, zero buldge would mean it's riding high in the center.
I didn't mean to start a debate, it just confirmed that my 35psi in my tires is correct...I've always ran 35 and just wanted to check. I agree, her explanation of the physics involved was a little sketchy but she wasn't hired for that, lol. She knows how to use the computer and the calculator and she was really nice...lol. Fink
__________________
#14 (permalink) |
Personal
Sales Rating: (0)
I've had BFG ATs on my 4runner for 80k miles. I have always run them, with and with out a load, at 30 psi. My last set wore out at 75k, totaly dead even tread.
__________________
| Tags |
| 00, 285, 4runner, 75r16, air, bfg, calculation, calculator, lt, max, pressure, presure, psi, recommended, tire, tires |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| TIRE PRESSURE?? Khumo 285 75 16s?? | BOSTON4RUNNER | Tires & Wheels | 2 | 06-20-2006 12:04 PM |
| 4 BFG 265/75R16 MT's on Factory 5 Star Rims | ecchamberlin | The Classifieds GraveYard | 25 | 04-25-2006 06:57 PM |
| Four 285/75R16 BFG AT's | 4Peanut | The Classifieds GraveYard | 21 | 04-16-2006 08:40 AM |
| Tire Pressure for BFG AT? | 4Peanut | Tires & Wheels | 9 | 03-16-2004 05:46 PM |
| Tire pressure for Bridgestone Revo 285? | Gringo | Tires & Wheels | 3 | 12-05-2003 07:16 AM |
