Tire Pressure & MPG
Tire Pressure & MPG
So, I bought some used tires and wheels... nice Bridgestone AT 10.5X31 on there, but the previous owner had run them at about 45lbs for years. So, the middles are thinner than the outside... I figured, for just schlepping around town I can lower the pressure to... 26-28 perhaps... wear on those edges... use them up. well....
I noticed the handling is not quite what it was, and my mpg went from 19-20 to 14-17
"DANG IT"
"DANG IT"
Tire pressure plays more of a role than most think, in handling and MPG.
many think that once air'd to a specific number....it wont move from that point...
sorry to hear that....bummer.....pay much???
I throw my advice on the table, MAX pressure stated on the tire, regardless of what the vehicle manufacturer recommends. Your handling and mpg will be MAX as well, BUT you may also wear on your tires and suspension components unduly. Depending on many variables, mostly how you drive.
i run my bfg mt's at 29psi up front and 32psi in the rear. i've ran them at 45psi and noticed improved gas mileage. but torsion crank lift + 45psi tires = bumpy ride... feeling every bump in the road is just not worth it, not to mention it probably isn't good for the tires. if i travelled any less i would probably run them all in the low 20s just for comfort
I used to run at 45psi until I drove a wash-boarded road at night and threw my alignment way out. Not to mention the coins in the ashtray, my fillings, and my girlfriend practically out the window. Higher tire pressure doesn't equate to better handling when the suspension can't keep the wheels on the ground.
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
itzmywife's
Jul 25, 2015 04:55 PM
