15x10's on 31x10.5/R15?
BFG recommends 7"-9" wide rim:
http://www.bfgoodrichtires.com/specs...t-a-ko/44.html
Might be a little stretched on a 10" rim plus you may have to shop around for a shop willing to mount them up for you.
10.50's will fit on a 10" wheel, but whoever puts the tires on will have to stretch the tire on. I have seen this done a few times, but if you wheel your rig you might have a problem with the tire coming off the bead. If I were to run a 10.50 I would get an 8" wheel.
i ran 31x10.50 on 15x10 wheels on my '88 toyota 4x4 truck for 10 years with no problems....just watch the curbs going through the drive thru window...lol...it's easy to scrape the rims....they stick out of the fender wells about 2 inches or so...i have a new 2009 tacoma now and i'm running 16x8 trd ivan stewart wheels with 265/70/16 bridgestone revo tires...looks really nice
Decided to go with these Dick Cepek DC-1 15x10 polished aluminum rims. I'll eventually upgrade to 31x12.5R15, or after I go 3.4, at least 32x11.5 with a minor bj spacer/ome coil lift.
I get scared thinking about curbage on 'em! That's not all too bad. Any pics of your truck(s)??
i was told the 'safe' min tire size for a 15x10 rim is 32 x 11.5. thats what i run right now and it looks great. as some others said you could probably do a 31x10.5 but it might not be the best for the tire (or rim). also different tire brands vary slightly in size so that might be something to consider also.
MxPx_Reaver
07-01-2004 07:22 PM
bigKahuna
09-29-2003 09:48 AM
