| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
4.3 v8 questions
__________________
sorry but still learnin!! 88 yota pickup 22RE/5spd 31" all terrains completly stock --------------- future [hopfully :)] rear locker 33" mud terrains SAS 3.4 swap!! |
#2 (permalink) |
Seriously?
First off, I'm assuming you mean V6, not V8 as you have in your thread title. Secondly, the 4.3 V6 is basically the same design as the SBC V8, with 2 less cylinders. Bellhousing is the same, and front accesories and everythng are the same. Third, there are several threads RIGHT UNDER YOUR NOSE in this very forum with 4.3 swaps. SEARCH! Hell, just look right below this thread. ......a grand for a 4.3???? I can buy a Vortec 4.3 for $250 You have A LOT of research before you go any further. Not that you will though, your just like the other 500 people on here that ask the same questions. Just a pipe dream.
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear Last edited by Adam F; 12-08-2008 at 08:29 AM. |
#3 (permalink) |
Do you mean the GM 5.3s little brother the 4.8?
#4 (permalink) |
My appologies if you meant 4.8L
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear |
#5 (permalink) |
no, gm made a 4.3 V8, they were optional in the caprices, the one i found is came from a 95 chevy caprice... and i meant $350 for the motor, $500 for the adapter, and whatever else i may need... and i know there are PLENTY of 4.3 v6 swap threads on here ha ha i think i've read at least half of them
__________________
#6 (permalink) |
OH. I've never heard of the 4.3 V8. My bad.
Wikipedia says its externally identical to the 5.7L LT1 In that case, the LT1 shares the same bellhousing as the older SBC engines. So the adapters should work. I guess it cant hurt to get the 4.3, as it puts out decent power. If you dont like it, you can always swap it for another SBC engine without reworking the bellhousing adapter.
__________________
#7 (permalink) | |
Quote:
That '95 Caprice was probably a taxi cab. How many miles do you think are on the engine?
__________________
1993 Toyota Xtra-Cab - Mods In Process: 5.7L TPI V8, 4L60, NP208, Dana 44 F, Ford 9" R, Lift |
#8 (permalink) |
I had a 4.3 V8 in my Dad's old (82) parrisienne. Almost the same as the 350, just less displacement. I was considering finding one for a swap, but they are not very popular anymore.
I am not sure about what was offered in the newer versions of this engine, but I had swapped an RV cam, 4 barrel carb and better exhaust manifolds to make it more fuel efficient and it ran great for over 400 K that we had it...
__________________
1985 RUNNER, supra engine conversion, SFArunning 32's, needs TLC; 1987 PICKUP, 22RET, electrical issues, IFS running 32s <RIP>;1989 COMANCHE, residential plow truck, daily beater; 1993 CHEV 2500, commercial plow truck, nick named BIG UGLY |
#9 (permalink) |
Staff
Specs are:
265 CI (4.3L) 200 hp 235 lb. ft of torque Bore: 3.736 Stroke: 3 Comp 9.9:1 sequential FI
__________________
David TLCA 14788 71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap. 76 Landcruiser FJ-40 project/parts (haven't decided) |
#10 (permalink) |
well the motor came out of the caprice, not sure if it was a taxi or not... but it was completly rebuilt with new everything for $350... i just need the computer and the wiring... and to put the accessories back on it... water pump, alternator, etc.
__________________
#11 (permalink) |
hey adam, how much did it cost you to put a 350 in your truck? and how hard was it? i'm just lookin for a ballpark number, i've seen everything from a few hundred bucks to 3 grand
__________________
#12 (permalink) |
After installing the 4.3 V6 in my 4runner I can't see trying to install a V8 theres just not that much room...
yes I know they do it all the time, but dang that thing is tight up front.
__________________
85 4runner, 3" spring lift, 4Crawler 2" body lift, Precision Gear 5.29's w/power brute posi frt & rear, M/T Baja MTZ 33x12.5x15, Warn M8000 winch, Optima redtop, Marlin Crawler Front, Rear Bumpers and Sliders, Allpro crossover steering & U bolt flip, LC rotors, '94 calipers and booster. 4.3 vortec / 700r4, Megasquirt II, EDIS6 |
#13 (permalink) |
1UZFE FTW
Nuff Said...
__________________
Screw you guys I'm goin to TTORA Mods, please be mature and leave my sig alone, thanks. No, I will not be your friend. |
#14 (permalink) |
Tight would be an understatement ![]() ![]() How much did the swap cost? I'm not counting. I don't want to know. I got my donor engine from a 76 blazer. Bought it for $250. Kept the motor. Sold everything else, got about $400 from parting it out. So I made $150 on the deal. And I used a bunch of scrap steel I had at home and at work to build other various components like core support braces and t-case crossmember. Adapter and clutch $800. Radiator $100. Electric fan, wiring, relays, switches $100 Motor mounts $75. Gasket kit and tune up for the motor about $100. Radiator plumbing maybe $30. Fuel lines $15. Power steering parts $40. Drive shaft work $150. Fluids $50. Welding and grinding consumables $50 Had to buy hoist and engine stand $175 Homemade exhaust $120 and a bunch more nickel and dime stuff I'm forgetting total? $1800. Thats a BALLPARK figure. Tons of stuff I'm leaving out. Not to mention the time put into this.
__________________
| Tags |
| 43, 43l, 48l, 57, 5spd, adapter, bellhousing, caprice, fj40, sbc, stroking, swap, v6, v8, work |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Another A/C Questions | jdw1 | 86-95 Trucks & 4Runners | 17 | 08-10-2008 07:01 AM |
| Just saying HI and a few questions. | bluemunkey1820 | 86-95 Trucks & 4Runners | 18 | 12-03-2007 08:07 AM |
| Questions. Questions. Questions. | shifty | 86-95 Trucks & 4Runners | 5 | 11-14-2007 04:54 PM |
| 4 RUNNER REAR END QUESTIONS...other posts i found in searches leave me with questions | BOSTON4RUNNER | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 11-24-2004 11:45 AM |
| CB questions... | Good Times | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 02-07-2003 02:36 PM |
