Diesel Swaps Diesel engines
wiring question
Old 07-17-2013, 04:40 PM
draggin209's Avatar
wiring question
Hey guys while I'm waiting for my adapter kit to come from Tdswaps I want to start removing all the wires I can. I know the efi wires can be removed but after tht I'm lost as to what can be taking out. The truck is a 2wd 22re if tht helps. Maybe a diagram with which ones removed would help me out a lot on both the computer an fuse box side thnx guys
Old 07-21-2013, 11:59 AM
waltt's Avatar
I just cut my harness about a foot out of the fire wall. Capped off all the wires. then i used the wires off of my alt to power the glow plug controller and shut off solnoid. as for gauges. my fuel gauge and volt meter still function as thay did b4. my factory oil and temp don't function anymore, and have been replaced with aftermarket ones in a pod on my A-pillar. if u want the stock gauges u will have to fit the Toyota senders to ur om617. Hope this helps. I can write up a color code if u need it.
Old 07-21-2013, 06:54 PM
draggin209's Avatar
If you could do tht for me it'd be great. I was gonna try an keep the Toyota gauges stock if I could Brian is supposed to throw those parts in for me. So I was just gonna eliminate what I wasn't going to use an keep everything very minimal.
Old 07-26-2013, 06:38 PM
waltt's Avatar
I posted my wire code on my thread. hope it gets u where u need to b.
Old 07-27-2013, 11:16 AM
draggin209's Avatar
Thnx ill go check it out
Old 07-28-2013, 02:09 PM
Captain Jack's Avatar
Tried to access with o luck. Can you please send to me?
Old 07-28-2013, 02:24 PM
waltt's Avatar
https://www.yotatech.com/forums/f162...ps-kit-269111/
that's the link to my thread. it will b on the second page.
Old 07-28-2013, 02:51 PM
Thanks Waltt, I have a 94 4Runner getting a OM617, 700r4 with a Dana 300 built with a LoMax 4:1 kit. Going with 4:88 gears. Are you near Vancouver? I am in Yakima.
Old 07-28-2013, 07:33 PM
waltt's Avatar
Ya just a few miles east. ur welcome to check it out if ur ever in the area .
the1998sr5
15
07-14-2020 08:35 PM
tj884Rdlx
08-28-2015 12:04 PM
rushw
07-18-2015 01:46 PM
icentropy
07-14-2015 10:23 AM
88yodabasket
07-13-2015 01:32 PM
Quick Reply: wiring question
