All Other Toyota Swaps I4, I6, Lexus V8
Swapping Engines in 93 Toyota pick up
Old 08-15-2010, 01:17 PM
tjbushey's Avatar
Hello, i have a 93 Toyota pick up 4x4 Manual Trans with 22RE engine, the engine is blown and need a new one, is it possible to put in the 6 cylinder version for this year? and if so what all do i need, Motor mounts?.....
Any help would be great,
Thanks for your time.
Old 08-15-2010, 02:08 PM
99blackSE's Avatar
You're going to need the ECU and harness for sure, and I would think some hoses or lines as well.
Old 08-15-2010, 02:48 PM
tjbushey's Avatar
Well i have the hole Truck that the 6 cylinder is in, so i could take all the parts out but was wondering if i needed to buy anything in order to switch them over.
Old 08-15-2010, 03:05 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
I'm pretty sure you'll need your motor mounts re welded to match the V6's correct location...
Then, you'll need to put the transmission in it b/c the 22RE's and V6's are not the same...
Then wire it up... It should work...
Old 08-15-2010, 03:07 PM
A 22R/E made anywhere from 1985 to 1995 will work.
http://www.lcengineering.com/TechNotes/?techid=49
Old 08-15-2010, 03:12 PM
tjbushey's Avatar
yea i know any 22RE will work just no money for another engine.
thanks for the info hope more people have some info.
Old 08-15-2010, 03:53 PM
What is the full rundown of the truck you have now, and the V6 you want to swap in?
Engine, trans, 4WD, 2WD?... Extended cab...?
People have, you just gotta know where to look...
Have you googled this idea? Is your google finger broke? (sorry, had to)
http://www.google.com/search?sourcei...22r+to+v6+swap
Old 08-15-2010, 03:55 PM
tjbushey's Avatar
The truck i have now is Extended Cab 4x4 Manual and the parts Truck is Reg Cab 4x4 Manual.
Old 08-15-2010, 03:56 PM
namely: 1988 22re swap with a 1988 V6 3.0
Old 08-15-2010, 04:02 PM
tjbushey's Avatar
thanks for the link, doesn't seem to hard, hardest part looks like the engine mounts, But not sure if a Reg Cab Transmission is the same the Extended.
Thanks for the help
Old 08-15-2010, 04:08 PM
oh, fiddlesticks!
All the info running rampant on the interwebs and I still don't know if the cross members of a 4 and 6 are in the same spot...
Last edited by tried4x2signN; 08-15-2010 at 04:10 PM. Reason: can't find a specific scan
Old 08-15-2010, 04:12 PM
tjbushey's Avatar
thanks for the link, But still need to find out if they are the same as the Reg Cab, guess only way to tell is to go out and Measure up!
Thanks again .
Old 08-15-2010, 04:15 PM
Fink's Avatar
Moved to the Toyota Swap section.
Please try and do some searching on this topic, namely in this section, to help answer your questions.
Fink
Old 08-15-2010, 04:27 PM
2DoorRunner's Avatar
Subscribed. I want to know if the crossmembers are the same too.
Old 08-15-2010, 04:28 PM
I have an r150 sitting in my shed with the crossmember on it, and a g58 (w56) in my 4runner. Why dont i just go get off my lazy ass and measure it
I will get an answer soon.
Old 08-15-2010, 04:33 PM
tjbushey's Avatar
lmao Alright
Old 08-15-2010, 04:44 PM
So the trans will bolt in as long as you use the v6 crossmember.
They have the same mounting locations. you just cant use the 4 cyl crossmember on the 6 cyl trans.
Old 08-15-2010, 04:53 PM
tjbushey's Avatar
Alright thanks for the info, Helped alot.
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
streetuner15
06-18-2015 10:59 PM
kcaudill
06-17-2015 08:27 AM
Quick Reply: Swapping Engines in 93 Toyota pick up
