inline 3.0 swap? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > All Other Toyota Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-13-2008, 03:32 PM   #1 (permalink)
backwoods_bently's Avatar
inline 3.0 swap?
hey yall i was seriously lookin into puttin a inline 3liter in my truck. i can get one out of an old supra, but will the tranny bolt up to it? they are alot better motors as far as i know. what all will be involved in it? also, does anyone have any idea what tranny came in the 94 v6 yota pickups? any help would be great. thanks fellas.
backwoods_bently is offline
Old 05-13-2008, 03:38 PM   #2 (permalink)
fillsrunner4's Avatar
Send a message via AIM to fillsrunner4
Lots of research first is what I would do as this and many other swaps have nemourous threads about the how to's and in's and outs of it all. Your tranny will worjk but you will need the 4cyl turbo bellhousing from an r151f. you have a r150f with a chain drive case. Search more and you shall find all you are looking for on this swap
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 39" Iroks, Rear Leafswap, 5.29's , Air locked front, Welded rear, Chevy 4.3L V6, 5spd swap, dual T/C's MC10R10, flatbelly with custom skids, sliders, Chopped, Bobbed and so much more.
Might as well start reading this if ya want know more
Fillsrunner4 3.4crawler Build Thread
Fillsrunner4.3 crawler (Part Two) build thread
fillsrunner4 is offline
Old 10-29-2008, 10:53 PM   #3 (permalink)
going to be a very tight fit, and that engine has alot of wierd positiond things, like its hard to get to alot of vacumm lines, bolts and water lines on that engine, its a hose mess sometiems.
94toyotapickup is offline
Old 11-21-2008, 10:26 PM   #4 (permalink)
bigtrucknwheels's Avatar
Send a message via AIM to bigtrucknwheels
Quote:
not for a 5M/7M swap, if he has an r150f, he needs to buy a custom bellhousing (around $350 dollars). if he has the 4 cylinder w56 transmission, then he needs to buy the bellhousing off the supra transmission (must also be a 5 speed).
For the 4 cylinder swap (22R series), simply use 5MGE motor mounts and the 7M block will fit on your original frame welded mounts. use the bellhousing, clutch, flywheel, clutch fork, and slave cylinder from the Supra, everything will bolt up real nice.
I intend to do this swap (seriously haha, not just talk) from my 3VZE to a 7MGTE. I will need to move my motor mounts and purchase the adapter bellhousing, and 5 speed swap my truck all at once haha. Its not as straight forward as the 4 cylinder swap, but the V6 manual is far more stout and will deal much better with my turbo charged swap. I plan to do some mods and am hoping to pull at least 300 horsepower at the rear wheels. its gonna be the truck from hell hahaha
but anyways, here is a good site for information:
Supra Charged!
bellhousing you'd need for a 3VZE swap:
Custom Bellhousing
__________________
Quote:
"For centuries, the battle of morality was fought between those who claimed that your life belongs to God and those who claimed that it belongs to your neighbors -- between those who preached that the good is self-sacrifice for the sake of ghosts in heaven and those who preached that the good is self-sacrifice for the sake of incompetents on earth. And no one came to say that your life belongs to you and that the good is to live it."
-- John Galt
Ayan Rand -- Atlas Shrugged
bigtrucknwheels is offline
Old 11-21-2008, 10:38 PM   #5 (permalink)
On second examination, it doesn't look as if you can actually purchase that bellhousing... make your own haha!
__________________
-- John Galt
Old 03-12-2009, 05:06 PM   #6 (permalink)
SupraRunner's Avatar
Since we are all assuming you have the 5 speed on that v6 and not the auto, you CAN avoid fabricating a bell housing, HOWEVER! it does involve swapping the output shaft from your r150 with the one in the 154 found on the back of that 7m turbo, (or my recommendation the 1jz), then your RF1a transfer case will bolt right up. And if you go with the 7m non turbo or 6m or 5m they have a w58 and you would need the output shaft from a w56 (found in I4 5speeds) to bolt a transfer case. All of these do involve getting the trans with your new motor, if you want to run with run with yours then yes, cut and fab or let the guys a Supracharged.com do it for you.
Hope this helps
SupraRunner is offline
Old 03-12-2009, 05:26 PM   #7 (permalink)
scuba's Avatar
ughh errr old thread much ?
__________________
Screw you guys I'm goin to TTORA
Mods, please be mature and leave my sig alone, thanks.
No, I will not be your friend.
scuba is offline
Old 03-12-2009, 08:32 PM   #8 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
Thats OK. If SupraRunner wants to dig up an old thread, let him. He's the #1 source of info on supra engine swaps.
Adam F is offline
Old 03-12-2009, 11:08 PM   #9 (permalink)
Quote:
is that supposed to be sarcastic or serious?
__________________
-- John Galt
Old 03-13-2009, 12:17 AM   #10 (permalink)
scuba's Avatar
Its just that, They guy who posted only posted in this thread twice, I think he either got deployed or he gave up the idea of the swap, while putting that info in this thread is good for some people, it doesnt negate the fact that he bought up a dead thread from a year ago.
But whatever...
__________________
scuba is offline
Old 03-13-2009, 06:15 AM   #11 (permalink)
Was only trying to get the information out there, there seems to be some interest in this swap, "while not much". I figured even if THIS guy has moved on, that maybe someone else searching this section for information might benefit from some discussion and information. (I thought that was the whole idea of this area?)
Just the Newbie trying to make some meaningful contributions.
__________________
91 4Runner SR5
Above all know this: "It will take more time and more money than you ever imagined".
Old 03-13-2009, 07:15 AM   #12 (permalink)
gilby4runner's Avatar
Send a message via MSN to gilby4runner
Easy there scuba....RELAX it is good info to have.
***at least its not a thread about fitting 35's with no lift.
__________________
2002 Sport- (Sporticus) OME 881 / 906 combo, Full Synthetics, 265/75/16 Geolander AT II's,
Brembo / Hawk combo,and a cool car seat for the future wheeler!
Quote:
Originally Posted by UKMyers View Post
What a disappointing thread. Great job bragging about being stupid.
gilby4runner is offline
Tags
30, 7m, bellhousing, car, custom, i4, inline, r150f, r151f, straight, supra, swap, swapping, toyota, truck, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
The sweet noises of a carbed inline-6 fo_runner Off Topic Talk 5 06-14-2007 10:37 PM
Two Catalytic converters inline, less polution? trythis 86-95 Trucks & 4Runners 14 03-26-2006 02:30 PM
Any Inline Skaters? bike4miles Off Topic Talk 22 03-01-2005 08:52 AM
4.5 Inline 6 for the 4Runner! JC_ez 95.5-2004 Tacomas & 96-2002 4Runners 4 02-05-2004 11:56 AM
inline fuel pump heliax 95.5-2004 Tacomas & 96-2002 4Runners 0 07-01-2003 12:12 PM
2009 InternetBrands, Inc.
