All Other Toyota Swaps I4, I6, Lexus V8
inline 3.0 swap?
Old May 13, 2008 | 02:32 PM
backwoods_bently's Avatar
inline 3.0 swap?
hey yall i was seriously lookin into puttin a inline 3liter in my truck. i can get one out of an old supra, but will the tranny bolt up to it? they are alot better motors as far as i know. what all will be involved in it? also, does anyone have any idea what tranny came in the 94 v6 yota pickups? any help would be great. thanks fellas.
Old May 13, 2008 | 02:38 PM
fillsrunner4's Avatar
Lots of research first is what I would do as this and many other swaps have nemourous threads about the how to's and in's and outs of it all. Your tranny will worjk but you will need the 4cyl turbo bellhousing from an r151f. you have a r150f with a chain drive case. Search more and you shall find all you are looking for on this swap
Old Oct 29, 2008 | 09:53 PM
94toyotapickup's Avatar
going to be a very tight fit, and that engine has alot of wierd positiond things, like its hard to get to alot of vacumm lines, bolts and water lines on that engine, its a hose mess sometiems.
Old Nov 21, 2008 | 09:26 PM
bigtrucknwheels's Avatar
not for a 5M/7M swap, if he has an r150f, he needs to buy a custom bellhousing (around $350 dollars). if he has the 4 cylinder w56 transmission, then he needs to buy the bellhousing off the supra transmission (must also be a 5 speed).
For the 4 cylinder swap (22R series), simply use 5MGE motor mounts and the 7M block will fit on your original frame welded mounts. use the bellhousing, clutch, flywheel, clutch fork, and slave cylinder from the Supra, everything will bolt up real nice.
I intend to do this swap (seriously haha, not just talk) from my 3VZE to a 7MGTE. I will need to move my motor mounts and purchase the adapter bellhousing, and 5 speed swap my truck all at once haha. Its not as straight forward as the 4 cylinder swap, but the V6 manual is far more stout and will deal much better with my turbo charged swap. I plan to do some mods and am hoping to pull at least 300 horsepower at the rear wheels. its gonna be the truck from hell hahaha
but anyways, here is a good site for information:
Supra Charged!
bellhousing you'd need for a 3VZE swap:
Custom Bellhousing
Old Nov 21, 2008 | 09:38 PM
On second examination, it doesn't look as if you can actually purchase that bellhousing... make your own haha!
Old Mar 12, 2009 | 04:06 PM
SupraRunner's Avatar
Since we are all assuming you have the 5 speed on that v6 and not the auto, you CAN avoid fabricating a bell housing, HOWEVER! it does involve swapping the output shaft from your r150 with the one in the 154 found on the back of that 7m turbo, (or my recommendation the 1jz), then your RF1a transfer case will bolt right up. And if you go with the 7m non turbo or 6m or 5m they have a w58 and you would need the output shaft from a w56 (found in I4 5speeds) to bolt a transfer case. All of these do involve getting the trans with your new motor, if you want to run with run with yours then yes, cut and fab or let the guys a Supracharged.com do it for you.
Hope this helps
Old Mar 12, 2009 | 04:26 PM
scuba's Avatar
ughh errr old thread much ?
Old Mar 12, 2009 | 07:32 PM
Adam F's Avatar
Thats OK. If SupraRunner wants to dig up an old thread, let him. He's the #1 source of info on supra engine swaps.
Old Mar 12, 2009 | 10:08 PM
is that supposed to be sarcastic or serious?
Old Mar 12, 2009 | 11:17 PM
scuba's Avatar
Its just that, They guy who posted only posted in this thread twice, I think he either got deployed or he gave up the idea of the swap, while putting that info in this thread is good for some people, it doesnt negate the fact that he bought up a dead thread from a year ago.
But whatever...
Old Mar 13, 2009 | 05:15 AM
Was only trying to get the information out there, there seems to be some interest in this swap, "while not much". I figured even if THIS guy has moved on, that maybe someone else searching this section for information might benefit from some discussion and information. (I thought that was the whole idea of this area?)
Just the Newbie trying to make some meaningful contributions.
Old Mar 13, 2009 | 06:15 AM
gilby4runner's Avatar
Easy there scuba....RELAX it is good info to have.
***at least its not a thread about fitting 35's with no lift.
Old Dec 28, 2009 | 01:17 PM
doctorturbo's Avatar
I'm looking for some help.
I have an 89 toyota supra 7mgte manual . I want to put the engine in my 4x4 toyota truck W56 5 speed trans. What bellhousing do I need ? I've searched and found conflicting information. A salvage yard here has an 87 supra 7mge (non turbo )with manual trans.
I'd love a little help here.
Old Dec 28, 2009 | 01:24 PM
thats precisely what you need. The bellhousing off the non turbo 7mge with a w series transmission. be sure to grab the clutch stuff too!
Old Dec 28, 2009 | 01:46 PM
Cool ! I was just at the junk yard feeling like I wasted some time because I'd heard you needed an automatic tranny bellhousing from a 7mge or 5mge. This is great then !!
Old Dec 28, 2009 | 01:48 PM
I'll start a build thread when I get some progress.
Old Dec 28, 2009 | 02:06 PM
sounds great man! Unfortunately, reality and practicality got in the way of me ever completing this swap, but I will be watching your build when you get started haha. Be sure to post a link in this thread, otherwise I probably won't see it.
And when you go back to the yard, you will wanna get anything and everything for the clutch. Clutch fork, slave cylinder, flywheel, clutch, and of course the bellhousing.
And, to aid with the installation of the motor, if you have a R series engine now, all you need to get is some 5MGE motor mounts and the 7M will literally bolt right into your truck. You won't need to make custom mounts or move your transmission. You will have to massage the firewall a little bit, but not a whole lot. The trickiest parts of this build are getting the power steering lines all set up and getting a fan/radiator combination that works well and doesn't rub.
Good luck!
*edit*
Not sure about the engine mounting and such on a first gen truck. I know on second and third gens its no problem, but don't take my word for it on that first gen haha.
Old Dec 30, 2009 | 08:47 PM
Adam F's Avatar
Dead serious.
This forum needs more TECH. Suprarunner brings the tech.
tobylab
Jan 18, 2016 07:06 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
93toyoguy
Aug 2, 2015 07:41 PM
jjrbus
Jul 23, 2015 05:05 PM
tobylab
Jul 12, 2015 12:53 PM
