| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
2jz-gte swap question
__________________
1996 Toyota 4Runner Stock/Hydrolocked Girlfriend's: 1991 Toyota Pickup Bobbed 9 1/2" | 3" BL | Soon to be sas'd. |
#2 (permalink) |
those are sweet motors try this guy
http://www.supratrucks.com/
__________________
1994 toy 22re- http://www.yotatech.com/f86/nocalsvx-s-94-toy-104593/ 2006 Subaru Forester XT -some mods/awd 5spd 1994 Subaru SVX- hwy runner 84 RX7- drag car build |
#3 (permalink) |
Take a look at http://www.supracharged.com/
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio |
#4 (permalink) |
I would like to know more on this also
#5 (permalink) |
can u build a custom oil pan and pickup tube? the 2jz uses an aluminum one that wont fit into a truck, any truck. that is the hard part, u can use the bellhousing off a 5 spd one to mate it up to a w series transmission. the r series bellhousing wont work, they are different lenghts. ive swapped a 7mgte into an 87 excab, it was easy. but the 2jz is a nightmare.
__________________
i drive by brail. Rock Solid Motorsports http://www.rocksolidmotorsports.net/ http://www.lunatic4x4.org/forums/forumdisplay.php?f=45 |
#6 (permalink) | |
Quote:
A Toyota 1JZ bellhousing and flywheel will allow you to bolt an R series trasmission onto the 2JZ, assuming you have a long input shaft. So, you're lookin at late gen R150, an R154, or an early R150 with a swapped input shaft. As for the swap, there was a guy who did a 1JZ/R154 swap into hjis V6 4runner. Do a google search, I'm sure you can find it. A 2JZ swap will be identical to a 1JZ swap. And yes, they are awesome motors. It's not as hard as people think. If you did a 7M swap into the truck, a 2JZ is not much different. A 1JZ is designed to fit where a 7M was, and a 2JZ is just a bit higher than a 1JZ, and has a LITTLE less clearance behind the rear turbo.
__________________
86 SR5 Turbo pickup Fiberglass bed, Fiberglass Fenders. 91 1.5JZ GT40 Supra. 77 Celica Liftback. (WTB: 20R Carb!) |
#7 (permalink) |
A couple of choices need to be made before you start.
1jz or 2jz: yeah the 2 is 3.0 vers 2.5 of the 1, BUT the 1jz with its r154 Will allow you to avoid cutting your bell housing, your output shaft IS too short to bolt to your transfer case, so you will need to rebuilt the 154 with your output shaft then the transfer will bolt up directly with nothing fabricated. Note: the 2jz that you would get would be JDM (the usdm would be 4k as apose to the 2k you see on ebay) will most likely be from a Aristo, this is a good thing it is much cheaper than the supra's, and if you mount it more rear "As explained below" then it already has a front sump pan that will require less modification to clear. Next decision: Your V6 sits more forward than the 4; so, you can bolt on your cross member but you will have to put a custom radiator down inside where the condenser and pusher fan is now, or swap a 4's cross member (it is strait as apose to the forward bend of yours) will allow everything to sit further back to fit a stock radiator. Either way you remove the clutch fan and put pushers in front. Forward Back ![]() I hope this helps. |
#8 (permalink) |
2 Jay Z Swap with NAS :
__________________
Screw you guys I'm goin to TTORA Mods, please be mature and leave my sig alone, thanks. No, I will not be your friend. |
#9 (permalink) |
how did i know that picture was going to end up on this thread lol ..wish i had some knowladge to contribute to this thread, all i know is that it would be wicked to have that motor in my runner
__________________
current: 1986 4Runner, Rebuilt 22RE with engnbldr HP head, cam'd, battery/intake swap, SASed, 5.29s, detroit rear, 35in MTRs, trussed and armored axles, marlin HD clutch, soon to be dual cased, TG rear bumper, Best mod todate CHROME METAL SR5 DOOR HANDLES, thats whats up RIP: 1985 Standard Cab SR5 pickup, add-a-leafs and shackels, 33" BFGs, it died a horrible death (50mph roll over) DD: 2006 Scion Tc w/TRD Supercharge and TRD stainless cat-back exhaust |
#10 (permalink) |
Oh ric's 1jz sc300........ Will that picture ever die.
__________________
#11 (permalink) | |
Quote:
Why can do same with the 2JZ???? Thanks for helping |
#12 (permalink) |
The R154 was never meant to be mounted to a transfercase. What you need to do, is swap the output shaft, and rear housing from an R150 (V6 truck/4runner) onto the R154. You can then bolt an R150 transfer case (or maybe more, I'm not sure) to the R154. Then you use a 1JZ bellhousing to bolt the R154 to a 1JZ or 2JZ motor.
__________________
#13 (permalink) | |
Quote:
1.- Are the 1JZ and 2JZ bellhousings the same? 2.- Are all 2JZgte VVTi????
__________________
Suzuki Samurai-Toys8"-ARBs-Iroks 36"-Looking for a new drivetrain |
#14 (permalink) |
No the 1JZ and 2JZ bellhousings are not the same.
The 2JZ has two different bellhousings. There was the 2JZ-GE bellhousing, which allows you to bolt a JZ motor to a W series transmission, and there was the 2JZ-GTE bellhousing, which is actually part of the Getrag V160 transmission, so it's useless in this circumstance. The 1JZ-GTE came in front of an R154 only, and that is the bellhousing you want to use. That will allow you to bolt a JZ motor to a R154. As for VVTI, no, VVTI only came out on the 2JZ (and 1JZ for those curious) around 1998. From 1991-1997, they had no VVTI. The 2JZ-GTE ceased production around 2002, while the 2JZ-GE is still in production for Lexus.
__________________
#15 (permalink) |
the 1jz-gte also came with a A-3040-LE, witch is just a AE with a locking converter, these are the 2 wheel version of the AH used is v6 auto's ,"this is the one with that awful integrated hydrolic transfer case". the 1jz with it's bell housing will actualy bolt right up to your factory auto "i would not recommend it", but you can, and i did just to get proper placement and work on fitting, i have put some effort in to trying to figure a way to use the ALE that came with the 1j and make it 4x4 with an old t-case from a I4 auto with divorceable t-case. i'll let ya know
__________________
91 4Runner SR5 Above all know this: "It will take more time and more money than you ever imagined". |
#16 (permalink) |
^^ I meant that as far as 5 speeds go, it only came with an R154
![]() Most Toyota motors also come with some form of an A340, and almost all of them can be mixed and matched.
__________________
| Tags |
| 2jz, 2jzgte, easy, gte, handle, horsepower, hp, jay, naz, pickup, potential, sale, sump, swap, toyota, tube |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 2JZ-GE + turbo swap | 4runner4ever | 86-95 Trucks & 4Runners | 95 | 04-25-2008 07:25 AM |
| 24R-GTE Tech | Bunta Fujiwara | General Vehicle Related Topics (Non Year Related) | 4 | 05-03-2007 11:41 PM |
| My 7M-GTE build | slacker | The Fab Shop | 12 | 09-13-2006 11:33 AM |
| 2JZ-GTE in the Tundra | DavidA | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 08-09-2004 05:53 PM |
