few questions about 3.4 swap
Old Apr 19, 2008 | 11:51 AM
dirtpup's Avatar
i know your gona say to look harder but i read once on here that you could reuse your 3.0 oil pan on a 3.4 is that pissible or not. and does anyone have the pictures labeled from the 3.4 wireing harness for when i might get to do my 3.4 swap so i can figure this out faster then taking a month to do this is my onley vehical to drive so im trying to do as much less down time as i can. thanks dirtpup.
Old Apr 19, 2008 | 02:41 PM
mt_goat's Avatar
Originally Posted by dirtpup
... i read once on here that you could reuse your 3.0 oil pan on a 3.4 is that pissible or not...
Should be able to use a 3.0 oil pan, but there is a little more to it than just swapping the pan, you also need to change the oil pickup tube.
Old Apr 19, 2008 | 03:39 PM
RobD's Avatar
http://www.andrewzook.com/content/view/22/48/1/3/
Old Apr 19, 2008 | 09:49 PM
dirtpup's Avatar
yea i saw that you need to reuse the pickup tube also. can you use the guage cluster form the 3.4 taco
Old Apr 19, 2008 | 11:00 PM
RobD's Avatar
I know of no one that's swapped the clusters. Swapping the oil pressure sending unit is critical, but the rest of the gauges work as advertised.
Old Apr 20, 2008 | 01:12 AM
Elvota's Avatar
The wiring is going to be different on almost every swap. Too many variables.
There are no real shortcuts.
You either have to pay with your time or money to get all the electrical to work.
Old Apr 20, 2008 | 07:38 AM
dirtpup's Avatar
so i use the 3.0 oil presure guage. so whats the best way to tell about the wires get a blow up of every thing for both vehicals and hope they are color coted
Old Apr 20, 2008 | 08:27 AM
Elvota's Avatar
You need the factory electrical wiring diagrams for both the donor vehicle(3.4) and the current vehicle(3.0).
To get them, you pay $10 per day here:
https://techinfo.toyota.com/techInfo....toyota.com%2F
The wires will all be color coded.
The other option will be to pay ORS to make a harness for you that simply plugs in and adapts the 3.0 body harness to the 3.4 ECM.
Old Apr 20, 2008 | 01:23 PM
dirtpup's Avatar
ok thats what i figured ill get it from tis at work and read the books and thel be helpful to me. thanks
one more question will my 5 speed form the 3.0 fit to the 3.4 or will i need a new bell houseing form a 3.4 5 speed
it says on this web sight that the old tranny will bolt right up but the flywheel form the 3.4 and clutch are bigger then the 3.0. http://www.andrewzook.com/content/view/22/48/1/7/
Old Apr 20, 2008 | 03:59 PM
RobD's Avatar
It will bolt right up. Use the 3.4 clutch and flywheel (which are bolted to the 3.4), then use the throwout bearing from the 3.0. Fits beautifully.
Old Apr 20, 2008 | 04:36 PM
dirtpup's Avatar
o ok thanks the funny thing is i just put a new clutch in my truck about a month ago. lol so i have a good throwought bearing one less thing to worry about
Old Apr 21, 2008 | 02:33 AM
dirtpup's Avatar
hey who is ors and whast there websight if they have one
Old Apr 21, 2008 | 03:21 AM
mt_goat's Avatar
http://www.offroadsolutions.com/technicalarticles.htm
Old Apr 22, 2008 | 07:27 AM
dirtpup's Avatar
hey thanks for the help im starting to get some money saved up for parts that im going to need. so ill let you know how it goes when i get a motor
Old Apr 22, 2008 | 08:53 AM
drk1's Avatar
dirtpup,
I'm in the process of doing this swap... It's been an on and off again thing for a couple of years now, but did give me pleanty of time to research and get my head around what's required.
I have a 1991 Pick-up V6, 5 Speed, 4X4 etc... and have completed the changes to the wiring harness. The 3.4L came from a 1998 4 Runner, and the ECU and harness from a 1998 Tacoma. I hear 97 and 98 are the easiest years for swaping the wiring.
As it looks like you have the same rig, and I can provide you with a copy of the changes I had to make. I have no Cruz or AC and only had to run a couple of new wires and/or repin three plugs (1@ECU(E8 or E5?) & 2 Body plugs C1 & C2)... I purchased wiring manuals from Toyota Distribution Center ph 800-622-2033 (in California I think?) and cost around $20 a pcs. I suggest you think about doing the same at least for the doner, as your going to get into a number if diffrent systems, back-up lights, ABS system, 4Wheel Drive, Combo Meter (speed sensor) and a few others that I can't remember right now.
Also... at least buy the crossover from ORS.. will save on the hassel of trying to build one and also try to get Exhaust manifolds from a 01 and up... as I've been told they flow as good as headers
Let me know and I'll make a copy for you...
Chow for now
Dan
Old Apr 22, 2008 | 12:35 PM
JGrund85's Avatar
Don't buy the crossover from ORS...it's like 400 bucks. You could get Downey headers for 410 shipped to your door and you'll get more power.
Also, all the wiring diagrams you need can be gotten off of techinfo.toyota.com. you can download all the toyota FSM's from there and they are very helpful.
You can also purchase a wiring harness from Yotaman. He will have it built in about a week and a half and has been extremely helpful to me during my swap. You can save a lot of money going through him.
There is also a thread on here discussing how to build your own crossover pipe for about 6 bucks.
Old Apr 22, 2008 | 12:41 PM
Elvota's Avatar
https://www.yotatech.com/forums/f160...r-pipe-138902/
Flying91
45
Apr 11, 2024 04:39 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
94whiterunner
Jul 12, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
Cplmike
Jul 8, 2015 08:47 PM
