EVAP VSV: Number of nipples
Any idea why my Vapor pressure sensor VSV would only have two nipples? as I was putting the rest of the EVAP together I ran into a wall.
I attached a few photos. The first is of the diagram I was following to set up my EVAP(96' evap setup). The second is of the location I grabbed the VSV from the intake manifold.
Did they change the EVAP system after 2000-01?
I'm at a bit of a loss as to how to explain it. But having replaced one like that on my sister's Mazda, I can assume it's probably similar in design. From what I understand of how it functioned, I'm having a harder time trying to figure out why one would have three nipples honestly.
Why two? That's all that's needed to allow the sensor to detect vapor pressure in the fuel tank, which is the whole purpose for it(I thought). That VSV is an electronically-controlled vacuum switching valve that allows vapor pressure from the fuel tank to travel in one hose and out the other hose to the sensor.
Why three? Maybe it has something to do with pressure in the canistor too? You tell me...I ain't that good at trying to guess what the OBDII does. Time to download that manual I suppose...
Oh, almost forgot. Just cap the line going to it that doesn't go to the fuel tank or sensor
justdifferentials
Just Differentials
06-13-2022 07:40 PM
