Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
1990 runner and question...
so im planning to do this swap...but..i mud a lot...which also means i go under water a lot..i need the snorkel....how will that work with the 3.4 swap?...
will the other snorkel fit?..whats the deal here? |
| Sponsored Links |
#2 (permalink) |
Any snorkel kit for the 3.4 should work, although you may need to do a little custom fitting since the fenders are not the same as the previous generations.
In my swap I fitted the intake duct from the 3.4 and there is more than enough room: http://www.yotatech.com/f160/my-truc...16/index5.html I don't know if snorkel kits for the 3.4 replace the duct or hook up to it, but either way shouldn't be any problem.
__________________
"If it's worth doing, it's worth doing right" my father-in-law 1989 4wd Xtra Cab 3.4L V6 A340F auto, '85 4Runner gear driven transfer case Alpine CDA 9857 3" Downey rear leafs, 1.5" BJ spacers Doetsch Tech shocks front & rear Next projects (in no particular order): TRD SC trail armor, bumpers LT suspension |
#3 (permalink) |
White Elephent, did you go through with the snorkel?
#4 (permalink) |
The 3.4 has it's intake on the passenger's side, the 3.0 has its on the driver's side. You'd need a snorkel that fits through your passenger side front fender, since the 2nd gen snorkel kits go down the driver's side.
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio |
#5 (permalink) | |
Quote:
People do however make there own all the time using pvc and whatnot!
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 37x14" Iroks, Rear Leafs, 5.29's , Air locked front, Welded rear, 4.3L, Chevy V6 , 5spd swapped, dual T/C's MC10R10, flatbelly with custom skids, sliders, and so much more. Might as well start reading this if ya want know more |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1990 4 Runner for sale | jdickerson | Vehicles - Trailers (Complete) | 7 | 07-09-2008 07:49 AM |
| 1990 runner in MN needs help | joehill | Newbie Tech Section | 2 | 04-06-2008 07:54 AM |
| 1990 Toyota 4-Runner | rodbender1 | Vehicles - Trailers (Complete) | 0 | 09-01-2006 03:22 AM |
| 1990 2 door runner in Va. | tyzsdaddy | Vehicles - Trailers (Complete) | 2 | 04-26-2006 03:37 PM |
| 1990 4 runner / 3.0L V6 engine question | Doc279 | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 01-26-2004 05:58 AM |
