Whistling, ABS light on, stereo cutting out, engine cutting out, HELP!
Old 05-19-2005, 11:10 AM
Randomness's Avatar
Unhappy Whistling, ABS light on, stereo cutting out, engine cutting out, HELP!
Guys WTH is wrong with my truck? There's a high pitched whine/whistle that increases with the RPM's; the cd player randomly cuts out every couple minutes; and the engine cut out for about 1 second; AND the Rear ABS light came on a couple times too.
I have absolutely no idea what is going on, and if anyone has any ideas, I'd REALLY appreciate it. Thanks!
Randomness is offline
Old 05-19-2005, 11:27 AM
cubuff4runner's Avatar
Is the whine coming from inside? A poorly grounded cd player will sometimes get let off horrible engine interference out of the speakers which will change with RPMs. Sometimes a short in one place will cause funny things to happen. I would try disconnecting the CD player first.
cubuff4runner is offline
Old 05-19-2005, 11:59 AM
Randomness's Avatar
That's a really good thought, jeff...I'll try that. How can I tell if it's not grounded properly? BTW, your Runner is probably my favorite one on here Your roof rack and front bar are so sick...
Old 05-19-2005, 12:18 PM
Thanks,
Is it a stock stereo or aftermarket? Usually if it is not grounded properly it will let out a whineing noise, but it should only effect the stereo, unless the ground for your stereo is slightly shorting on something else. I don't know if a corroded negative battery terminal will have the same effect, but it may be worth taking a look at. Electrical problems are always fun
Old 05-19-2005, 12:30 PM
Randomness's Avatar
It's an aftermarket one... My battery terminals look ok, and I would assume any corrosion would be visible? Oh yeah, they're great especially with me being SO great with any wiring type stuff...oh wait, I suck at that stuff
Old 05-19-2005, 04:15 PM
You may want to consider checking the wiring on your cd player since it could have been installed poorly. Hopefully somebody else will chime in with an idea.
Old 05-21-2005, 03:07 PM
Randomness's Avatar
FIXED! Turns out it was the wire that goes from the POS battery terminal to the 80A alternator fuse. Guess it's a common problem in 2nd gens, so I followed ROMAD's write up and replaced it with 6ga wire that I soldered on the fuse side. Works perfect! Thanks for all your help!
ashersullivan88yota
01-18-2022 05:37 PM
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Gamble_STi
07-07-2015 07:54 PM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: Whistling, ABS light on, stereo cutting out, engine cutting out, HELP!
