What kind of grease?
depends on the application... i used marine bearing grease on my front hubs on my old 4x4 ford because i knew i was going to have it in deep water and did not want to repack the bearings all the time... if you use marine grease you need to make sure it can handle the stress of being used in whatever application you are using it in... i had this blue grease that i used and it actually said on the container ideal for 4x4 and trailer hubs.....
Thread hijack, but didnt 4wheel off road have an edition about "green grease?" Its supposedly supposed to resist elements like marine grease or something special like that. I havent even seen them yet.
I just replaced and packed my front bearings using Mobil1 synthetic wheel bearing grease. Its a maroonish-red color and seems to be working well although I admit I am not sure I could tell a difference from one grease to another - just figured synthetic is a nice improvement over regular.
I've got an '88 pickup, 4WD, manual hubs. What size socket do I need for the wheel bearing nut? I've heard 54mm and I've heard 55mm. Didn't mean to hijack the thread... just thought it was an opportune time to ask.
TIA,
Troy
TIA,
Troy
ashamsuddin
17
01-13-2023 03:17 AM
kawazx636
10-06-2021 03:03 PM
live4soccer7
05-11-2016 06:52 PM
myotherrideisayoshi
09-29-2015 05:41 AM
