| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Toyota Type T-IV fluid equivalent
#2 (permalink) |
You might like to check Amsoil. I think they have a Dexron III ATF that meets Toyota T-IV requirements.
HTH.
__________________
1996 Pearl White Hilux Surf KZN185W SSR-G l 3.0L TDI l Dual Battery l LT285/75R16 l Recaro Seats Drive Your Dreams |
#3 (permalink) | |
Quote:
But is the Toyota T-IV similar to either the Mercon or Dextron III or Ford type F, or is it completely different? I'd like not to mix dissimilar fluids on a regular fluid change where not all the tranny fluid is exchanged. Surely not every one on this board with an auto tranny uses the Toyota brand fluid. What do the rest of you use? |
#4 (permalink) | |
I use Dexron 3. Dex 3 and Type F are totally different fluids for the different types of clutch materials used in the tranny so you cannot mix them. I was unaware that Toyota had a different type of fluid.
__________________
1998 4Runner SR5, Surco Safari rack, diff breather mod, Cobra WXST II CB radio, 31" Winston ATs, clear corner/bumper lens, hitch mount backup lamps, PCV catch can. Quote:
#5 (permalink) |
Toyota specified Dexron II or higher for my truck's tranny (A340F). I use Red Line High Temp ATF which meets Dexron III requirements.
Toyota came out with a T-IV ATF early in the 1990's, I think, but they reverted back to Dexron II/III. However, I was told that late model Land Cruisers (UZJ100) came out specified with Toyota T-IV atf. It is my understanding that Toyota T-IV atf meets Dexron II/III requirements. I just don't know if Dexron II/III meets Toyota T-IV requirements. EDIT: High-end ATF brands (such as Red Line and Amsoil) usually meet both Dexron III and Mercon IV requirements. Product specifications and referenced standards are usually indicated in the product label. But I think Type F should NEVER be mixed with either Dexron or Mercon atf. HTH.
__________________
1996 Pearl White Hilux Surf KZN185W SSR-G l 3.0L TDI l Dual Battery l LT285/75R16 l Recaro Seats Drive Your Dreams Last edited by KZN185W; 08-28-2005 at 06:13 PM. |
#6 (permalink) | |
Quote:
It is interesting to hear that Toyota has specified Dexron in the past. |
#7 (permalink) |
Here you go:
http://www.amsoil.com/products/trans...fluid_rec.aspx I tried the Red Line site but there was no mention of a Red Line ATF that's compatible to Toyota T-IV requirements: http://www.redlineoil.com/products_g...sp?subcatID=19 HTH.
__________________
#8 (permalink) |
Roy, thanks for the Amsoil link.
Well, earlier today I went to the Toyota stealership and they gave me a discount on a 12 qt case of T-IV. So I bought it. I was told by the parts guy that they get asked that question about compatibilty with Dextron. He claimed that the T-IV is synthetic and also that Dextron III is really not compatible. I guess that is what I would expect him to say.
| Tags |
| 30, a340f, atf, dexron, dexront, fluid, fluids, iv, price, sale, specs, surf, synthetic, tdi, tiv, toyota, trans, type |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| rear end fluid type? (middle of locker install look inside for type) | FOCUSHERE | 84-85 Trucks & 4Runners | 3 | 10-21-2006 05:22 PM |
| what type of radiator fluid do i need? | fireteacher | General Vehicle Related Topics (Non Year Related) | 38 | 09-11-2006 04:21 PM |
| What type of trans fluid is best | theryanator | Maintenance & Repair Archives | 7 | 11-03-2005 11:50 AM |
| How to tell between Type II, III or IV hitch? | Ontario | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-11-2005 09:32 AM |
| trans fluid type? | burntaco | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 05-21-2004 05:22 PM |
