Radiator Flush
Radiator Flush
Should i flush my 98 4runner radiator fluid or just drain and fill?
I bought mine 9 months ago and don't know if it's ever been done.
What is the mix ratio of toyota red fluid to distilled water?
Re: Radiator Flush
Re: ???
Originally posted by phosho
Red fluid? Are you talking about some flushing agent or the coolent? The toyota red fluid I know is tranny fluid and is not very effective in the radiator
I know there are various colors of anti-freeze, red, green, orange (GM brand), and i think I heard of a yellow verison too.
Oh if you are adding 50/50 solution to make it, use only Distilled water!
Re: Re: ???
Location: Home: Aurora, CO; Work: The People's Republic of Denver
Distilled is recommended for all vehicles. It has all the trace mineral & metals removed, thus the water is completely nuetral and won't accelerate corrosion in the cooling system.
Noel
Thanks for all the replies fellas. I meant the toyota red factory coolant.
It took exactly 1 gallon coolant and 1gallon distilled water for the radiator and reservoir. The old coolant looked really clean.
Sounds good, when I did mine it was a little darker than the new coolant, but was still clean. Will flush it again before we move back east or at 60k, which will be about 17k from now.
Originally posted by ben95m
Is the flush something I can do, or should I take it to the shop?
How often is it recommended to do it?
I just used a garden hose to flush it with only water because those chemical flushes can eat up your radiator.
A true flush though involves removing your thermostat, flushing the block, core heater, etc.
The way i did it should suffice at least 80% of particulates. But if you have overheat probs. i would do the major flush.
Just my $.02
Just my $.02
You can do it yourself or take it to a shop, just make sure that you use or specify the Toyota Long-Life (red) coolant.
You should do it every 12 months or 15k miles, usually about once a year. Keeping that schedule will keep your cooling system clean and efficient.
scott90
10-04-2015 09:21 AM
