| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
I got the beeps, the creeps, and the bleeps...(clutch)
__________________
-Jon Red 88 4runner - 5Spd - 22re |
#2 (permalink) |
This is not the return bushing as I have dealt with that before...
__________________
#3 (permalink) |
probally the linkage on the housing. my old 79 did that... push in the clutch w/ the windows down and you hear creeeeeakkkk! on that one, it had an old linkage w/ a pivot that had metal-to-metal contact. i caked some marine grease on the pivot for the cable, and it quit.
#4 (permalink) |
I'd say linkage or the clutch pivot point for the actual pedal
__________________
-Geoff *1991 Toyota Pickup Ext. Cab SR5 4x4 V6 5 spd K&N intake, port & polished heads with OS valves, port & polished intake manifold and plenum, NWOR headers and crossover, NWOR catback, Denso Iridium plugs, Redline Fluids, 4.88s, Rear LockRight, Aisin hubs, Chevy springs, BJ spacers, 2" RB body lift, 34x10.5 Swamper LTBs, WolphisWorks Sliders and bumpers, 400,000 mi. |
#5 (permalink) |
where is this so called "linkage" located? is it next to the tranny? I learn as I go as far as maitenence goes and havent dealt with the clutch or any of its parts...could someone point me in the right direction so I could try to through some grease on this thing?
__________________
#6 (permalink) | |
Quote:
__________________
www.rimpainter.com Get your O Gasket Mod Here! My SC'd 4Runner's Profile My YouTube vids |
#7 (permalink) |
Christian, a couple months ago....that was an interior noise when I dealt with it.
This is entirely external.
__________________
#8 (permalink) |
OK cool. Have you stuck your head under there by the clutch release fork while someone pushed the clutch pedal in and out? That will help you narrow it down. I bet the squeak is coming from that pivot point.
__________________
#9 (permalink) |
thats the linkage I was talking about down at the slave cylinder/ fork while your down there check to see if your slave cylinder is leaking or shot (easy to tell theres fluid all over the motor, bellhousing, transmission, frame etc.) Also while your on the subject of squeaky clutches hit the pedal pivot point w/some WD40 just to prevent it from squeaking on you
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| gear/clutch damage caused by clutch start? | el camino | 86-95 Trucks & 4Runners | 8 | 01-26-2007 02:35 PM |
| Clutch grinding, poor shifting, cracked clutch pedal bracket | T100NewMexico | 93-98 T100s | 10 | 09-22-2006 01:31 PM |
| PHONE CALLS w/ BEEPS | ROOFGOOF | Off Topic Talk | 10 | 12-14-2005 08:47 AM |
| Will the height adjustment of the clutch pedal affect the wear of the clutch? | YotaJunky | Maintenance & Repair Archives | 6 | 11-21-2005 08:03 PM |
| Napa Clutch vs. Toyota Clutch (94 SR5 4x4) | sunflower | Maintenance & Repair Archives | 8 | 05-08-2005 01:57 AM |
