Half moon grommets? 22re - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-29-2004, 10:00 PM   #1 (permalink)
gumbo's Avatar
I need to adjust the valves on my '86 22re. Ihave the valve cover gasket. Do I need to replace the half moon shaped grommets between the valve cover and the head? The valve cover gasket does leak and it looks like it is leaking in front,among other places.Thanks in advance. Jacque
__________________
96 Tacoma
06 Tacoma
toyotatrailriders.com
gumbo is offline
Old 01-29-2004, 10:18 PM   #2 (permalink)
HaveBlue's Avatar
Send a message via AIM to HaveBlue
It's a good idea to replace both the crescent grommets and valve cover gasket at the same time.
When I adjusted my valves, I bought the complete gasket and grommet set from AutoZone for less than $12. The funny thing is, the valve cover gasket alone was more than the kit.
http://www.autozone.com/servlet/UiBr...ction=loadPage
The kit comes with valve cover gasket, semi-circular grommets, and valve cover grommets.
I created a write-up on my website detailing valve adjustments on my '83 22R:
http://www.haveblueonline.com/1983/ENGINE/valves.htm
Hope that helps!
__________________
Alan
1996 Supercharged 4Runner Limited
Hi Altitude 4Lo A 4WD club for Colorado and surrounding states
HaveBlue is offline
Old 01-29-2004, 10:37 PM   #3 (permalink)
gumbo's Avatar
Thanks, Alan!
__________________
96 Tacoma
06 Tacoma
gumbo is offline
Old 01-30-2004, 07:55 AM   #4 (permalink)
toy283's Avatar
Send a message via ICQ to toy283
You didn't get new ones with the valve cover gasket? I always have. Unless you bought at the dealer, every valve cover kit I've seen comes with them.
__________________
Dave
Currently own no Toyotas :(
toy283 is offline
Old 01-30-2004, 09:55 AM   #5 (permalink)
gumbo's Avatar
Dave no I did'nt. It only came with the valve cover gasket and the 4 grommets for the valve cover bolts. It is a fel-pro gasket set. Maybe it should have the crescent shaped grommets?
__________________
96 Tacoma
06 Tacoma
gumbo is offline
Old 01-30-2004, 05:52 PM   #6 (permalink)
Arnold's Avatar
Every Fel-Pro gasket kit I've used always came w/ the half moon things. I also use a small amount of gasket sealant on 'em to prevent leaks.
Arnold is offline
Old 01-30-2004, 06:26 PM   #7 (permalink)
toy283's Avatar
A little research at Fel-Pro's website came up with the following:
VS50358R - Valve cover set including cylinder head endplugs and grommets
VS26081R - Valve cover set w/o cylinder head endplugs and grommets
The fact that your set came with the grommets but without the endplugs is puzzling.
__________________
Dave
toy283 is offline
Old 01-30-2004, 06:52 PM   #8 (permalink)
gumbo's Avatar
After reading Alan's post I took the gasket set back to Autozone and sure enough the set was supposed to have come with end caps . They swapped out the kit no questions asked. thanks for the heads up. Jacque.
__________________
96 Tacoma
06 Tacoma
gumbo is offline
Old 01-30-2004, 07:12 PM   #9 (permalink)
toy283's Avatar
Lot of good in that. Glad it all worked out in the end.
__________________
Dave
toy283 is offline
Tags
autozone, cover, valve, vs50358r
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Drilling new grommets through firewall Erich_870 Vehicle Audio & Home Entertainment 7 02-19-2007 07:29 PM
Quick 2nd gen help... grommets in firewall ? nrgetic99 General Vehicle Related Topics (Non Year Related) 6 12-13-2005 05:39 AM
Half paint half line-x? 89macrunner 95.5-2004 Tacomas & 96-2002 4Runners 13 06-02-2005 11:19 AM
Which silicone for firewall grommets Corey 95.5-2004 Tacomas & 96-2002 4Runners 7 04-04-2003 12:51 PM
2009 InternetBrands, Inc.
