Dropping front Differential for service???
Old Jan 15, 2004 | 06:47 AM
Flygtenstein's Avatar
I finally have a garage and time, so I am trying to get to the bottom of my leaky ARB locker in the front of my 95.
The air line and compressor are not leaking as tested with soap bubbles and similar. The rear locker works and cycles the compressor every couple of locks, but the compressor shuts down appropriately. When I engage the front, the compressor just runs. I am assuming a dead o-ring in the locker.
What do I do with the two vaccuum lines that connect to the ADD sleeve and stub axle? Just yank them off?
The wiring harness has a clip that will disconnect.
The ARB air line will screw out.
The diff breather can disconnect with the hose clamp.
The two vaccuum lines are all the is vexing me.
Thanks,
Adrian
Old Jan 31, 2004 | 05:12 AM
Bulkhead's Avatar
Check out this page http://www.off-road.com/toyota/tech/add/index.htm
jasonty
41
Dec 23, 2018 01:00 PM
Ladythump
22
Nov 9, 2015 08:53 AM
jerusry
Oct 19, 2015 05:28 PM
scottyg486
Jul 19, 2015 05:34 PM
AaronM
Jul 8, 2015 07:15 PM
