Funky rattling noise under neath the steering...
Old 05-04-2005, 11:57 AM
2001Millrunner's Avatar
this rattling noise is coming from drivers side firewall/steering colum. I checked underneath and checked all the relay and stuff are in place. It not a sqeek, sounds like a plastic box is hitting against the firewall causing a rattle. I just cannot locate it and it's annoying me! any ideas?
2001Millrunner is offline
Old 05-04-2005, 12:07 PM
Godzilla's Avatar
i had the same symptoms. check your heat shield around your engine to see if it is hitting anything.. mine was tapping on a brake line and i thought it was something plastic in the dash! drove me nuts until i found it.
Godzilla is offline
Old 05-04-2005, 01:37 PM
oh goody. I'll check that today, thanks
ashamsuddin
17
01-13-2023 03:17 AM
zytra
01-24-2019 03:16 PM
Davebarbier
11-03-2015 03:28 PM
Flightguy
10-02-2015 05:34 PM
Quick Reply: Funky rattling noise under neath the steering...
