Free O2 Sensor Replacement????????? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Maintenance & Repair Archives
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-05-2005, 05:11 AM   #1 (permalink)
gohawks's Avatar
Reading the owner's manual it indicates that Toyota will replace the oxygen sensor at no charge (parts & labor). This is in the maintenance section of the manual. I have a 1988 4Runner.
Just curious if that is ONE time at 80,000 or if it is still the case and they will do it EVEVY 80000 (can't imagine that it is).
__________________
SERENITY NOW!!
gohawks is offline
Old 07-05-2005, 09:54 AM   #2 (permalink)
Guest
Call them and ask.
That's all that you can really do and it does'nt hurt to ask.
94x4 is offline
Old 07-05-2005, 10:41 AM   #3 (permalink)
gohawks's Avatar
Yes, I guess that is what I'll have to do. Thanx.
__________________
SERENITY NOW!!
gohawks is offline
Old 07-05-2005, 11:44 AM   #4 (permalink)
Guest
That would definitely be worth knowing as those damn things can run ya' a couple hundred dollars or so!
94x4 is offline
Old 07-06-2005, 11:02 AM   #5 (permalink)
let us know what they said...
__________________
'99 Limited 4Runner
Clear Corners
Alpine CDA-9833
Alumapro Alchemy 12" woofer
Alpine V12 660 Watt 5 channel amp
K&N Air Filter
Running Boards removed
Soon to be...
new wheels and tires
t009166 is offline
Old 07-06-2005, 11:13 AM   #6 (permalink)
etgunner's Avatar
cali emission o2 sensor???
Since we are on the subject of O2 sensors...
I just found out my truck has California emissons and need to replace my O2 sensor. After price checking at URD I found that the Cali part is more than twice as much as the non-cali part .
Does anyone know if I can use the non-cali O2 sensor since I do not live in California?
etgunner is offline
Old 07-06-2005, 11:16 AM   #7 (permalink)
jimbo74's Avatar
Send a message via AIM to jimbo74
etg, nope the CA computer will flip out if you try and use a Fed spec o2 sensor......
jimbo74 is offline
Old 07-06-2005, 11:39 AM   #8 (permalink)
etgunner's Avatar
Thanks Jim...guess i will have to bite the bullet.
etgunner is offline
Old 07-06-2005, 02:41 PM   #9 (permalink)
gohawks's Avatar
Talked to Toyota on the phone and they did some research and told me that you only get one freebie and the mileage has to be 80000 or just under to get the free replacement (I'm waaaaaayyyyyy past that). I might try to hit up a dealership to see if they will go for it since I know its never been done on my vehicle.
__________________
SERENITY NOW!!
gohawks is offline
Old 07-07-2005, 01:15 AM   #10 (permalink)
Guest
"gohawks", "etgunner", you guys could try to save a few (read as: bunch of) dollars by pulling the 02's out and burning the buildup off of them with an acetylene torch, scrubbing them down with a steel brush and perhaps spraying them down with some quick drying, electric parts cleaner to remove whatever remaining residue, and then popping them back in.
It either may or may not be necessary to pull the fuse to reset the circuit, depending on your year, although I'm not certain.
94x4 is offline
Old 07-08-2005, 12:33 AM   #11 (permalink)
marko3xl3's Avatar
Send a message via AIM to marko3xl3
Do you know where to get an acetylene torch if you don't have one and don't wanna dish out the same amount as 2 o2 sensors for the torch? Like renting it or something
Edit:
I just researched some, and I found out that you can a simple home depot torch and a propane gas cylinder, about the same temperature. You could also use MAPP gas with the same torch, but I hope that doesn't burn the sensor @ 5500C . If anyone has more information about this, please post
marko3xl3 is offline
Old 07-08-2005, 05:50 AM   #12 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
This may or may not work and requires some technique to do (has been covered already in a few threads) because the part you need to clean is actually underneath the tip of the O2 sensor (not the tip itself). The only no brainer way, which is guaranteed to work is to replace with a new one. You can bench test the sensor with a torch to see if the sensor is indeed the problem before you replace it (but for most, if you do the work to get it out, you might as well replace it too).
If you want to try testing and cleaning, here is a good thread for you:
http://yotatech.com/showthread.php?p=521317#post521317
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
O2 Sensor Replaced for Free? mike92runnerSR5 86-95 Trucks & 4Runners 41 11-07-2007 07:27 PM
Free O2 sensor replacment AH64ID 86-95 Trucks & 4Runners 17 04-16-2006 01:16 PM
O2 sensor Replacement george16 95.5-2004 Tacomas & 96-2002 4Runners 2 05-19-2005 06:20 PM
Free O2 Sensor 14thegipper 95.5-2004 Tacomas & 96-2002 4Runners 7 10-24-2003 06:05 AM
O2 sensor replacement? russellcframe 95.5-2004 Tacomas & 96-2002 4Runners 24 09-30-2003 08:08 PM
2009 InternetBrands, Inc.
