engine stalling after drving for a while...
I have a problem that i really need help with. After i have been driving for a while and my truck is quite warm, but not overheating,then i park it. when i go to start it again within about 15-20 min, it will not start, if it does it will chug along until it either dies or will make it and start running normally. Recently i drove to tahoe and it did great until the traffic was backed up and then it died, it started a few more times but kept on stalling until it would not start again. I popped the clutch and continued to drive it, but had to keep it moving otherwise it would stall. Please tell me what you think the problem may be, any help is greatly appreciated. thanks again. -aaron
Sounds like a good place to start with the fuel filter. If I recall, my friend has a 22re and the fuel filter is pretty hard to get to.
Just a shot in the dark, but perhaps you might want to check your air filter and the engine for vacuum leaks.
Did a little reading on some other sites concerning rough running 22REs, and people had different suggestions. Some suggestions were easy like checking your spark plug wires, spark plugs, pvc valve and air filter.
I also read that it could be a valve or timing issue, but it seems those two would be a problem even when the engine is cold.
Something else you might want to try is cleaning the throttle body. I did it on my 97 Tacoma and it was fairly easy. Should be even easier on yours.
Read this thread. It has a couple of links that should help out. The links are not for the 22RE, but is should be close enough to figure out what you need to do.
https://www.yotatech.com/forums/show...=throttle+body
Seattle_Sign_Guy
07-12-2015 12:38 PM
Jnkml
07-06-2015 01:20 PM
