54 mm spindle nut socket
Old 01-31-2003, 03:10 PM
channer's Avatar
Okay, this time I did a thorough search of the forums, and I can't seem to find out where I can buy or rent a 54 mm socket.
I have called AutoZone, Advance, Napa, PepBoys... none seem to have it. Any suggestions?
channer is offline
Old 01-31-2003, 03:24 PM
Co-Founder/Administrator
Staff
Corey's Avatar
Somebody putting on some manual hubs soon?
I hear a Sears socket sized at 2 1/8 is the same size as 54 mm and should work.
I think Sears does carry one also.
Corey is offline
Old 01-31-2003, 04:26 PM
Guest
oly884's Avatar
I recently did my brakes, and a 2 1/8 works. NAPA carries them, but I had to get mine ordered.
oly884 is offline
Old 01-31-2003, 04:39 PM
channer's Avatar
Thanks for the info. Sears shows it online, hopefully they have it at the store, because my Mom won't loan me her IS 300 for long!
Sears 2-1/8" Socket
channer is offline
Old 01-31-2003, 04:54 PM
Shane's Avatar
The Sears one is nice, makes for a handy compact hammer too 'cause it's beefy. You'll likely need a 3/4-1/2 drive adapter too...
Shane is offline
Old 01-31-2003, 10:10 PM
RWD
http://www.sleeoffroad.com/products/...train_main.htm
RWD is offline
Old 02-01-2003, 08:40 AM
Arnold's Avatar
I got mine at my local Toyota dealer.
Arnold is offline
Old 02-01-2003, 01:05 PM
Cebby's Avatar
Got mine today at Sears
Got a 2 1/8" and adapter today (thanks Shane, I'd have forgotten) Socket was around $20, adapter was $7. I'm going to repain my hub dials for the 3rd time. First try was with body shop paint through a sprayer (turned out like ˟˟˟˟˟ - paint must have had hardner in it or something - like trying to spray molasses), 2nd was with the yellow my tow hook is painted with (the wife talked me into it - poor coverage, weird buildup at the letters). 3rd time is a charm - got some Plasticoat touchup spray to match the body.
Cebby is offline
Old 02-04-2003, 12:57 PM
Firescooby's Avatar
Are these needed in the new Tacomas? I have a 2002 and had a 1994 and have a 54mm socket from NWOR that I had to buy when I redid my hubs.
IF it is not needed in my Tacom I was gonna sell it.
Firescooby is offline
Old 02-04-2003, 08:33 PM
Adam F's Avatar
No, Tacoma's and 3rd gen 4Runners use a 36mm socket
Adam F is offline
Old 02-06-2003, 07:47 PM
oldsub86's Avatar
I got a 54 mm socket last fall at my local autoparts store. They had lots of different ones for various 4X4 hubs including the one for the 2nd generation Runners. It was expensive and obviously has limited uses but was worth it to me. It is thin walled so it fits without rubbing. Someone suggested that the 2 1/8 sockets can sometimes be a bit tight. I don't recall the brand on mine and it is out in the cold garage so I am not going to look right now but if you have trouble finding one, post again and I will look and tell you what the brand name is.
oldsub86 is offline
Old 02-21-2003, 05:29 AM
Firefyter-Emt's Avatar
believe it or not.. this is one socket that is not expensive thru Snap-On.. and it is the correct socket.. (I think I paid under $20)
Firefyter-Emt is offline
Old 02-21-2003, 04:30 PM
Yoda's Avatar
My local NAPA has the OTC 54MM socket for toyota hubs for less than $15. And it is 1/2 inch drive. It has a newer number now (7612??) The one I have is 6612
I think the 95 (or so) Runners use a different socket (more expensive)
Yoda is offline
Old 02-24-2003, 08:09 PM
4x4CPOSEADOG's Avatar
I got mine from the guy ( I think he is a dealer) who drives Snap On truck for 16.55 plus Va tax and went to Sears to get the 1/2 to 3/4 drive adapter for 6.99 and since I was at Sears I decided to grab a torque wrench that goes from 5-80 ft lbs for $76 dollars, they were on sale. I need these tools to install the manual locking hubs. Below is the picture.
Noel
Attached Thumbnails 54 mm spindle nut socket-54mm-socket-half-inch-three-quarter-adapter.jpg
4x4CPOSEADOG is offline
G-off
12-29-2015 12:44 PM
Obmi
10-04-2015 11:30 AM
voiddweller
10-02-2015 07:47 AM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: 54 mm spindle nut socket
