| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
1985 22re sputtering
#2 (permalink) |
Could be the EGR is opeing too soon. Check the BVSV (Bi-metal Switching Valve) to make sure it is not letting vacuum through to the EGR modulator until the engine is warm.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#3 (permalink) |
I coulden't belive how far off my timeing was, and the engine still ran!! It was like a new engine...(oh yeah ...it is a new engine).
At least check the timeing.
__________________
85 4-Runner, New Engine, Auto Tranny ,4" Lift, 32" Tires, Flowmaster Muffler, Suntop Soft Top....BLÅH....BLÅH....BLÅH..... There Are Few Problems In The Galaxy Which Cannot Be Solved By A Suitable Application Of Concentrated Phaser Fire.
#4 (permalink) | |
Quote:
I've been having the same exact problem for awhile but I've ignored it since the engine runs fine after warming up. However, I'd like to correct this problem. I'm a bit of a newbie when it comes to working on engines. I've tried cleaning out the throttle body and the air valves around it in case they were clogged but that didn't help. How would one go about 'checking' the BVSV and EGR and where are they located? If you have info on your site, feel free to point me there rather than retype everything. I appreciate any help anyone can shed light on what seems like a somewhat common situation with the 22RE. Peace, Justin
__________________
1985 4Runner :.: 2" BL :.: 3" Downey suspension lift :.: BFG 33x10.5 Mud Terrains :.: MTX 10" sub (stolen. boo) :.: long list of expensive upgrades |
#5 (permalink) |
EGR valve is at the back of the intake plenum, big rusty cast iron "thingy". Modulator is the round plastic thing atop the valve cover with vacuum lines running to it and one that runs to of all places, the EGR valve. Follow the vacuum line from the modulator along the v/c to a gray plastic thing beklow the TB with 2 vacuum lines connected to it. One of those comes from the TB, and one goes to the EGR-mod. Its purpose is to block vacuum when cold, open when warm, passing vacuum to the EGR-mod. Simple test is to see if vacuum is present on the BVSV outlet when cold. The facotry service manual has full testing details. It it quite siple if you just follow the lines and make sure vacuum is present when it is supposed to be and not when it is not.
__________________
#6 (permalink) | |
Quote:
What's an easy way to check for the vacuum? Take the hose off and feel for air moving? Sincerely yours, Mechanically D. Clined
__________________
#7 (permalink) |
A vacuum gauge is the likely tool to use, since it is made to measure "vacuum". Even better option is to get a hand-operated vacuum pump with gauge attached and you have two tools in one. A gauge to test vacuum with and a pump to apply vacuum to testing vacuum operated things with. And add a brake bleeding kit and you can also bleed brakes with the same tool:
![]() http://www.jcwhitney.com/autoparts/P...oup?Ntt=vacuum
__________________
| Tags |
| 1984, 1985, 22re, 4runner, 65, bleeding, brakes, bvsv, egr, galaxie, inclines, modulator, sputtering, system, toyota, vacuum |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1985 Toyota p/u 22RE | Danno | 84-85 Trucks & 4Runners | 6 | 09-19-2006 04:30 PM |
| 22RE sputtering exhaust | Tacoma Dude | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 10-13-2005 01:58 AM |
| 1985 22re EFI Engine Sputtering!!! | ktmrider37 | Maintenance & Repair Archives | 0 | 05-02-2005 07:18 PM |
| 85 22re Engine sputtering?!?! | ktmrider37 | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-17-2005 03:59 PM |
| sputtering 22RE?? | bain | 95.5-2004 Tacomas & 96-2002 4Runners | 20 | 09-17-2004 04:50 PM |
