Engine Swaps Swapping an engine in your Toy, here is where to learn how
Remove dipstick?
Old 09-20-2011, 01:48 PM
RajabuYota's Avatar
Remove dipstick?
I'm swapping my 22re for a rebuilt one and can't figure out how to remove the dipstick so I can install it into the new one. Any help?
Old 09-20-2011, 01:53 PM
xxxtreme22r's Avatar
Pull straight up just like you would if your checking the oil.
Or do you mean the dipstick tube?
Got to unbolt it from the block and it should come right out.
Old 09-20-2011, 01:55 PM
snobdds's Avatar
I just gave mine a good yank - for lack of a better term.
If it's really tight, just take a sharp chizel and CAREFULLY go around the bottom where it meets the block and pry it up. It's just pressed fited in there.
Old 09-20-2011, 01:57 PM
dang it snobdds now I got to go look at mine, I coulda swore mine was bolted down.
Old 09-20-2011, 02:00 PM
snobdds's Avatar
The top part has a little holder that bolts to the block/head, but where it goes into the block is just a press fit.
Old 09-20-2011, 02:31 PM
RajabuYota's Avatar
Haha my mistake, I meant dipstick tube... so it pulls straight out with a little elbow grease? Sounds good, I was worried that it was welded in or something. Thanks!
Old 11-02-2011, 01:28 AM
Rebel Lady's Avatar
yes I tried pull the tube of oil dipstick and cant pull it out.
Old 11-02-2011, 02:33 AM
suncomb1's Avatar
Drop the oil pan, take a punch that is close to the dipstick hole ID, spray WD-40 and gently tap it out. Doing it this way you will not damage the dipstick tube. I just replaced mine with a Lokar unit.
Old 11-02-2011, 03:01 AM
Rebel Lady's Avatar
thanks,Suncomb1
I ll do..
Old 01-10-2012, 11:31 AM
Newby's Avatar
Great that you got it out.
choppe777
05-16-2016 08:00 AM
Anthony Lee Mathis
09-15-2015 07:22 AM
gp66
09-07-2015 08:29 AM
viesail
09-05-2015 04:23 AM
Aaron Logan
09-03-2015 08:08 AM
Quick Reply: Remove dipstick?
