Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Just finished my motor swap with a new 22re, its runs but i have no oil pressure. I replaced the oil pressure sensor. When i turn it on the pressure gauge comes off of the peg but its just below the operating arch. what can i check or change without ripping the motor apart again?
__________________
92 DLX Pickup X-Cab 22RE 4X4 manual 4 Inch Trail Master lift |
| Sponsored Links |
#2 (permalink) |
its exactly the same as the old engine. It came with a new pump installed by www.sunwestautomotive.com
__________________
#3 (permalink) |
hmm.. do you have a manual one handy?
__________________
91 Toyota stdrd cab short bed 22re 5spd. sas'ed, Yukon 5:29's. 3.5" tuff country e-z ride springs in the front. 5" allpro long travels in the rear. pro comp es 9000 shocks, 12" tg long spline front d shaft. k&n, 35x10.50x15 boggers. cobra cb/ashtray mod, 3' fire stick. etc. 2000 Toyota Tacoma xtra cab sr5, 3"revtek,285/70/17 coopers stt, clear tails, injen short ram intake, obx header, flow master, etc. 2001 Toyota Camry, the girlfriends, www.22re.com |
#4 (permalink) |
a manual oil pressure gauge, no. the repair manual, yes but i didnt see anything on trouble shooting low oil pressure
__________________
#5 (permalink) |
i was talking about a gauge.. see if you can get one then check for oil pressure! that will tell you if its the gauge, or not. eliminate the idea of a faulty gauge.
just my .02
__________________
#6 (permalink) |
Use an oil pressure tester and see what your actual oil pressure PSI is
http://www.harborfreight.com/cpi/cta...emnumber=92687 |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| NEED HELP! - Low oil pressure & leaky oil breather | boosted86 | 86-95 Trucks & 4Runners | 4 | 08-12-2008 09:10 PM |
| Questions about oil pressure and oil pump replacement on 3VZE | ThomasJ | 86-95 Trucks & 4Runners | 2 | 11-28-2007 05:39 PM |
| Oil pressure & Trans Oil Temp Install ?? | Jayota | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 07-18-2007 08:59 AM |
| Oil pressure & Transmission Oil Temp Install ?? | Jayota | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 07-16-2007 10:13 AM |
| Best location for new oil sender (Autometer oil pressure gauge) | Bob_98SR5 | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 10-20-2004 03:13 PM |
