No oil pressure
Just finished my motor swap with a new 22re, its runs but i have no oil pressure. I replaced the oil pressure sensor. When i turn it on the pressure gauge comes off of the peg but its just below the operating arch. what can i check or change without ripping the motor apart again?
its exactly the same as the old engine. It came with a new pump installed by www.sunwestautomotive.com
hmm.. do you have a manual one handy?
a manual oil pressure gauge, no. the repair manual, yes but i didnt see anything on trouble shooting low oil pressure
i was talking about a gauge.. see if you can get one then check for oil pressure! that will tell you if its the gauge, or not. eliminate the idea of a faulty gauge.
just my .02 |
Use an oil pressure tester and see what your actual oil pressure PSI is
http://www.harborfreight.com/cpi/cta...emnumber=92687 |
