carbureted 4.3 swap fuel pump problem
Hi guys! Ive done the carbureted 4.3 swap on my 93 but am experiencing some issues with the new frame mount fuel pump. the new pump is pulling thru the original in-tank pump and after about 45 minutes of running the pump stops sending fuel. I have tried several things now...exchanging pump (was still under warranty)...have set up a line to a jerry can behind the pump to by-pass the in-tank pump...check if its getting power when pumps stops working but i can't figure this out.
Has anyone run into this?
westonian18
02-04-2016 04:56 AM
