| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
89 3.0 to chevy 350 swap
Last edited by fordsnrebels; 06-21-2009 at 08:31 PM. Reason: being more specific |
#2 (permalink) |
Radiator, fan, exhaust, drive shafts, wiring, body lift, possibly suspension lift
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear |
#3 (permalink) | ||
i bet the oil pan will hit the ifs components on a stock height truck
__________________
Quote:
Quote:
1993 yota pickup. 3 slow, 4.56 gears 5 speed. plumbing isr. autopal h4 conversion, 12 inch infinity sub. 3 inch body lift with 33'' tsl's |
#5 (permalink) | |
Quote:
Yup, thats why I said body and suspension lift
__________________
#6 (permalink) |
Check out that site I posted. They make a different oil pan that will work with the IFS and stock height
#7 (permalink) |
sounds good. I have 90% of that stuff. am I able to keep my rad in same spot. and motor mounts. its gonna need that right? IFS was a big concern for me if it was going to clear. 300 bones is a pretty price for a oil pan.
#8 (permalink) |
i have a 85 4-runner put a 350 sbc in alot of work but its great-theres alot of stuff you wont realize untill u do it but it was all worth it.
#9 (permalink) |
Yes, you will need motor mounts. The chevy motor will not bolt up where the Toyota motor was
You might be able to keep the rad in the stock location if you go with a electric fan, short water pump and all the matching pulleys.
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear Last edited by Adam F; 06-22-2009 at 11:25 PM. |
#10 (permalink) |
So i'm guessing I'm gonna have to chop the drive shafts? I'm planning on motor mounts and oil pan and slapping the engine in. Considering it came out of a Yota lots of parts should be ready.
#11 (permalink) |
I higley reccomend a summit aluminum radiator and a 16" high flow electric fan thats does around 2000cfm or 2 10" fans pushing the same. This is how I cool my 1uzfe.
__________________
1988 Toyota truck with a 1UZ swap http://www.yotatech.com/f158/88-toyo...s-more-181467/ |
#12 (permalink) |
go ahead n do it then let us know how it goes, I'm olmost in the same boat, 350/350/205, one guy was doing this set up, but I lost his tracks. I heard that an easy/unexpensive way to clear the oil pan is to add B/J spacers. =1.5" /crank the torsion bars = 1"/and drop the differential,= 1", and to clear the distributor You will need some b/lift + a good hammer, remember the more you push the engine back the more space to set the radiator. don't worry about lifting the truck, that will make your work easier. once everything is set n ready you can go back and lower it untill you clear all exesses and feel happy. salud.
| Tags |
| 30, 350, boat, swap |
