inexpensive hand winch suggestions? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Trip Planning, Trail Reports-Photos, Land Usage-Responsibility, 4Wheeling 101, & Expedition Gear > 4Wheeling 101
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-01-2008, 10:53 PM   #1 (permalink)
I am thinking about buying a mechanical hand winch and there appears a huge range in price and options out there. I am looking for something affordable, but up to the task of pulling my truck out of a ditch. Realiabity is obviously important, but not necessarily long term durabililty. I don't plan to use it regularly, just have it in case. I drive a lot in the snow and want some way of independantly pulling myself out.
How does using a Hi-Lift as a winch compare other manual winches?
Will_4R is offline
Old 11-02-2008, 08:14 AM   #2 (permalink)
tc
tc's Avatar
Well, my first recommendation would be good tires and proper driving to not end up in the ditch in the first place!
The only problem with Hi-Lift winching is you can only go 48" (or 60" depending on which HiLift you have) at a time. But, it works well. I highly recommend everyone who has a HiLift to get the winch accessory kit (note: you need a section of 3/8" Grd 70 transport chain that is NOT included in the kit!)
A hand winch or come-a-long will work OK, but will be slow. You will need one rated at least 4 tons (8000 lbs), just like a motorized winch - and even then, you may have to double line pull if the snow is deep. Snow up over the axles is a huge "mire factor" and dramatically increases the load on the winch.
I think getting a nice, high end manual winch would be a better decision than a cheap motorized winch.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 11-03-2008, 03:08 PM   #3 (permalink)
Quote:
I would also advise using a hi-lift, with their winching kit and chain. Their are plenty of videos on youtube that demo how it is done, just search "hi-lift winch".
But be aware that their size is in reference to their frame, and not the amount of travel in the jacking mechanism. For example, a 48" Hi-lift, the nose starts at 4.5" from the base, and it stops at ~37-38", so there is only 33"-34" of true "winching" before you have to re-adjust. And a 60" Hi-lift has 44"-45" of travel. But still, with a little practice, you can use it very effectively!
__________________
1985 4x4 Extended Cab, 22RE, E-locked rear, 4.7 MC Gears
BigO is offline
Old 11-03-2008, 08:12 PM   #4 (permalink)
Thanks for the replies, it seems like a Hi-Lift is probably the best way to go since it is a more versitle tool. I was planning to get one anyway, but since it will require adding sliders to my truck so I can use it as a jack as well, as was going to wait a bit. I guess I should fork over more dough right away and skip the comealong.
How does the mechanical advantge of the hi-lift compare to a comealong-type winch? I mean terms of how much muscle it takes to do work. It looks easy enough in the you tube vids, but if a rig is really stuck...
Will_4R is offline
Old 11-03-2008, 08:23 PM   #5 (permalink)
ocdropzone's Avatar
Get a More Power Puller
I have had a More Power Puller (8K double line pull) for over 15 years...it has only quit working when I get tired
Probably one of the best investments for 4Wheeling I have got:
http://www.wyeth-scott.com/
it is the only thing the company makes:
have used it to pull stumps, trucks and comes in handy when you don't have your transfer cases installed
weights a bunch but better than a regular come a long and faster than trying to use a high lift jack for a winch, for single line it has almost 35 feet of cable on it...I carry my Hi-lift too...
__________________
~Robb
'81 Trekker The B4Runner Build
TREKKER Forum
Mini FAQ/Misc Ideas Thread
**TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES
LINK TO ONLINE FACTORY SERVICE MANUALS
Drive a real 1st Gen
Wheel Responsibly, Don't Screw It Up for Others
ocdropzone is offline
Old 11-04-2008, 01:08 AM   #6 (permalink)
muddpigg's Avatar
I have limited experience with hand winching, I tried it with my Hi-lift once. I did not like it at all and felt that it was not a exceptible tool for winching.
Yes, I saw the youtube and hi-lift infomercial.
Still carry it but would get a come-along if I was planning to manual winch.
__________________
http://www.youtube.com/watch?v=rqtr_RvR3sY
Balljoints for sale. Open to trades and offers. http://www.yotatech.com/f11/ball-joi.../#post51278784
muddpigg is offline
Old 11-11-2008, 02:11 PM   #7 (permalink)
SR5
SR5's Avatar
i have one of these, not the same company, but the same. and it works AWSOME, i love it, and would highly recomend it
__________________
1995 SR5 V6 4Runner
SR5 Profile
SR5 is offline
Tags
cable, car, case, ditch, hand, oregon, power, pull, puller, small, tool, video, videos, whinch, winch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
inexpensive gearing toyota4life23 86-95 Trucks & 4Runners 15 11-03-2007 02:35 PM
Tundra setup with a winch = a lot of rake...suggestions? nc994run 95.5-2004 Tacomas & 96-2002 4Runners 36 07-30-2006 10:21 AM
Come-along hand winch Rishi Offroad Tech 17 06-08-2005 01:00 PM
2-ton Hand Winch Scofco 95.5-2004 Tacomas & 96-2002 4Runners 10 03-26-2004 03:19 PM
Hand Versus Power Winch Denk 95.5-2004 Tacomas & 96-2002 4Runners 12 05-30-2003 03:15 PM
2009 InternetBrands, Inc.
