| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
"After mudding" maintainence?
__________________
"And they called him a Hebrew Slave" 2003 Tacoma Prerunner, Double cab, 3.4 5VZ-FE, auto. 2wd, rear e-locker My Profile (06/09/07)-Deckplate-(07/14/07)-ISR-(08/27/07)-WARN 4300K HID lights-(11/22/07)-True-Cool Tranny Cooler-(12/25/07) -Tru Flow air filter-(12/25/07) -Husky Floor Liners-(02/14/08)-ScanGaugeII-(04/30/08)-Glassworks Unlimited hood-(12/22/08)-Dynomax Muffler- |
#2 (permalink) |
Make sure you didn't get any water in you rear diff through the breather, unless you've extended. Another than that I always just power wash everything real well, you'll know if your bearings need repacked.
__________________
2006 Tacoma SR5 - Stock for now 2000 4Runner Limited 16x8 Pro Comp Steelies wrapped in 285/75R16 Pro Comp M/T'S~RB 2" Body Lift~SS 1.2 Lift~1st Gen Roll Bar~Surco Safari Rack~ Trail Gear Sliders~Deckplate Mod w/ True Flow~Satoshi Grille~Hayden 1678 Aux Cooler~Safari Snorkel and a bunch of other crap..... |
#3 (permalink) |
A lot depends on the muds consistency. If it was real soupy watery mud than you should remove the drums and clean your breaks out well with break parts cleaner. Buy a few cans. Be careful power washing around your front breaks though.
#4 (permalink) |
I agree with cleaning the drums. If they aren't working properly, then the front brakes will be working too hard and may end up warping the rotors. After that, I would just keep an eye on the inside of the wheels just to make sure that no gear oil is seeping past the inner seals. If you start to notice any gear oil you will want to replace the inner seals as soon as possible so you don't wash all the grease out of the bearings. You can't repack the bearings on your truck really. A new one will have to be pressed on if it needs replacing.
__________________
-Marcus 1997 4Runner Limited 4x4, E-Locker, Bilstein HDs, Air Springs, Deckplate Mod, 265/75/16R Bridgestone Deuler A/T Revo |
#5 (permalink) |
Thanks a ton guys!
__________________
#6 (permalink) |
you guys forgot a very MAJOR component that gets fouled easy in mud.
Your front wheel bearings. You should repack them. |
#7 (permalink) |
you might as well repack the front wheel bearings if you have the time and tools (and grease); check the diff fluids; get under your truck with a hose and clean it all out by hand.
i love mud. and i am fine with the consequences of playing in it my neighbors hate me for it. i usually bring home a few hundred pounds of it on/under my truck and it falls onto the street
#8 (permalink) | |
Quote:
__________________
#9 (permalink) |
i use the power sprayer in my driveway and when the mud gathers at the end, i just push it in front of the tweaker neighbors house. haha
#10 (permalink) |
Re-pack your spindle after you do your wheel bearing, too.
A dry-spindle chatters like the dickens..
__________________
1987 Toyota Pickup DLX. 30" Cooper Discoverer S/T's. 1" AAL lift and Tbar crank. and two KC HiLites. IFS Club #5 1978 Camaro Z28, 454 Big Block V8 with a 4 Speed. |
| Tags |
| 2002, 4runner, bearings, clean, cleaning, front, mudding, prerunner, properly, repack, tacoma, truck, wash, washing |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| TRD Coil 4Runner lift that sits 2" front & 2.5" rear. "Mild" system for the masses! | sschaefer3 | Vendor Advertising | 11 | 11-29-2006 06:08 PM |
| Bilstein shocks for 1.5" lift. 10", 12" or 14"??? | BAZ | 86-95 Trucks & 4Runners | 3 | 11-06-2006 12:38 PM |
| New Music Video From David "The Hoff" Hasselhoff - "Jump In My Car" | OutdoorLiving | Off Topic Talk | 5 | 07-18-2006 09:26 AM |
| The official "How many miles on this part?" or "Is this normal wear?" thread.... | 4RUNR | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 11-28-2003 10:10 AM |
| ISR Mod "capped" vs "uncapped" (performance numbers) | rimpainter.com | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 05-22-2003 09:39 AM |
